Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-08-2009   #1 (permalink)
levyfamily3
New Member
levyfamily3 is an unknown quantity at this point
Leaky valves?
Need to know if I need to replace valve seals. Engine is 2000 civic si b16 doch. Few misfires, straight pipe no cat. Blueish, grey smoke when I downshift and when I come to a complete stop. To remove this ad, register today for free or log in if already registered!
levyfamily3 is offline   Reply With Quote
Sponsored Links
Old 07-09-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Leaky valves?
yes if you are burning oil
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 07-09-2009   #3 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Re: Leaky valves?
You could be burning oil from bad oil rings.
sql_civic is offline   Reply With Quote
Old 07-20-2009   #4 (permalink)
JREJ8
Member
JREJ8's Avatar
JREJ8 is an unknown quantity at this point
Re: Leaky valves?
compression test it. if the test reads low cylinder pressure then pour alittle oil into the cylinder though the spark plug hole and retest. if the pressure rises then you have bad piston rings and you need a rebuild. if not then you have bad valve seals or a bent valve or something in the head wrong.
__________________
1997 Honda Civic Si(R) Coupe EJ8
-JDM B16A SiRII swap
-DC 4-1 headers
-Skunk2 2.5" test pipe
-Skunk2 Megaflow Catback
-AEM Cold Air Intake
-Go-Autoworks B-series Radiator w/ 12" slim Fan
-Skunk2 Pro Series Full Coilovers
-Voxx Racing 17" Rims
-Yokohama Parada Spec 2 rubber
-Bisimoto Stage 2 Cams (soon to be installed)
cheap, fast, reliable. Pick Two.
JREJ8 is offline   Reply With Quote
Old 07-20-2009   #5 (permalink)
JREJ8
Member
JREJ8's Avatar
Re: Leaky valves?
but yes you are burning oil for sure:
blueish smoke: burning oil
black smoke: running rich
white smoke: Burning coolant/water.
__________________
-DC 4-1 headers
Old 07-20-2009   #6 (permalink)
denice25
Member
denice25 will become famous soon enough
Re: Leaky valves?
replace it when they have leaks... or try to compression test first...[img]http://******************/images/e98741479a7b998f88b8f8c9f0b6b6f1.gif[/img]
denice25 is offline   Reply With Quote
Old 07-20-2009   #7 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Re: Leaky valves?
I think I have a head gasket rebuild kit for a B18. I could double check it your interested. It has everything, head gasket, valve seals, every other kinda seal, etc. I bought it on accident when looking for a D series one. Its unopened.
TRIZ is offline   Reply With Quote
Tags
b16 , civic , misfiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
