Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-05-2009   #1 (permalink)
zXeX
New Member
zXeX is an unknown quantity at this point
Question about stock intake...
I posted a photo to show a part that a car I just purchased is missing. What does it do, and will its absence damage the engine?
zXeX is offline   Reply With Quote
Sponsored Links
Old 07-05-2009   #2 (permalink)
Tragedy
skate or die
Tragedy's Avatar
Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all Tragedy is a name known to all
Re: Question about stock intake...
That is the stock (oem) intake filter box. The box serves as a housing for the air filter, which filters dirt and debris from entering the intake manifold. I have seen some stock intake systems have the filter closer to the engine too, and some systems have a big box just for air passage and as a catch can I suppose.
Without this part you are subject to dirt,bugs,sticks,leaves,gravel, etc... getting into your intake piping, then in to the intake manifold, then deeper into the abyss.
wow.
__________________
"Unless someone like you cares a whole lot, nothing is going to get better. It's not."
-Dr. Seuss, the lorax
http://www.civicforums.com/forums/signaturepics/sigpic35349_1.gif
Tragedy is offline   Reply With Quote
Old 07-05-2009   #3 (permalink)
Mavrick272
Member
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
I don't think it's really necessary. To put any aftermarket intake on you have to remove it anyway.
The guy before you probably had an aftermarket intake on and then for whatever reason removed it before selling the car to you
__________________
'98 Honda Civic
'74 Porsche 914 (for sale!)
Mavrick272 is offline   Reply With Quote
Old 07-05-2009   #4 (permalink)
jason123
New Member
jason123 is an unknown quantity at this point
the filter for the intake is actually on top of the throttle body it is probably just louder with that part missing
jason123 is offline   Reply With Quote
Old 07-05-2009   #5 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
I'm not too famil with your engine, but the stock intakes have a resonator and a filter. Both are boxes. Removing the resonator will make your intake sound a little louder- nothing crazy tho. Removing your intake filter is just dumb because you can get crap in your engine.
TRIZ is offline   Reply With Quote
Old 07-06-2009   #6 (permalink)
zXeX
New Member
Yea, the filterbox is def' on top of the TB w/ filter installed. I guess as long as there's no harm no foul with this other box missing, I won't worry about it too much for now. Though I'm sure I will get a little more heat soak....
Old 07-08-2009   #7 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Triz is correct. That is a resonator. It's an empty box to muffle the sound. There's no filter in it. Your car will just run louder without it.
sql_civic is offline   Reply With Quote
Old 07-11-2009   #8 (permalink)
DanielsSTEK
New Member
DanielsSTEK is an unknown quantity at this point
yeah the filter's in the other box... back in high school I took that piece off (resonator) for months because I liked the sound when I opened the throttle up... your car will be just fine
__________________
My car will never be done.
DanielsSTEK is offline   Reply With Quote
Tags
2000 , 6th , car , civic , damage , engine , honda , intake , make , photo , remove , removing , resonator , sound , stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
