Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-29-2009   #1 (permalink)
Tiffany1229
New Member
Tiffany1229 is an unknown quantity at this point
Question 97 Honda Civic CEL blinking
Hi guys
I'm new here, so be easy on me. I'm hoping this is the right place to post this.
I have a 97 Honda Civic EX 2 DR coupe with a 1.6 dy168 motor, with vtec. I have been having problems with it anyway, and the CEL came on a few months ago. Took it to ASE certified master mechanic, claims after he re set the timing the codes 'went away'. I took it to Autozone a few weeks ago and it was throwing a P1259 code. I've read this one means vtec system malfunction, right? Anyway, my mechanic said that before the error codes 'went away', he was getting the vtec code and a code about a misfire between cylindars 2 and 4 I believe. Yesterday, I took the vtec solenoid off and cleaned the screen (read that on another forum) and put it back together. Checked the connections going to and from the oil pressure switch and vtec solenoid. On the paper I printed out that was out of some guys Civic book, it said pull the ECM fuse to reset the ECM. I did that and also pulled the negative battery cable, to make sure the code was gone. I made sure everything was hooked back up and went for a test drive. Car did fine at first, 2-3 minutes into drive I attempted to hit vtec and the light came back on and the car starting shaking like it was going to die, and eventually did die three times at stop lights. Got it back home and was messing with it and the CEL starting blinking. I don't see how just removing the solenoid to clean the screen and replacing everything as it was would of caused this. Does anyone have any ideas as to what the problem might be? I really don't want to have to take it to the shop if its something I can do myself. Thanks in advance.
Tiffany1229 is offline   Reply With Quote
Sponsored Links
Tags
16 , 19962000 , 97 , blinking , cel , civic , code , dy168 , honda , idle , list , misfiring , motor , problem
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
