Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-21-2009   #1 (permalink)
ProVic
New Member
ProVic is an unknown quantity at this point
leaks leaks leaks
what is the most common leak for the 6th gen civic?
my engine has a leak. i checked out like 4 other civics and its all the same place. between the tranny and the engine block
ProVic is offline   Reply With Quote
Sponsored Links
Old 06-21-2009   #2 (permalink)
lilmidget08
Member
lilmidget08's Avatar
lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned
Send a message via AIM to lilmidget08
Re: leaks leaks leaks
well that would be the rear main seal leaking. but also take a good look at your oil pan gasket they tend to leak from time to time.
lilmidget08 is offline   Reply With Quote
Tags
civic , common , leak , places
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
