Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-18-2009   #1 (permalink)
astroturf5
New Member
astroturf5 is an unknown quantity at this point
Lightbulb Engine Trouble, need intervention
ok, I don't know much about cars(computers are my thing) so please don't flame me for asking stupid questions...so here's the question: I have a 2000 Civic EX Manual Transmission 1.6 SOHC engine that just died on me, like totally dead, unrecoverable and I was wondering if instead of buying and dropping the base engine back in(non-VTEC) if it was possible to buy a VTEC and use that instead??
Please help me, I've looked everywhere and can't find a definitive answer.
astroturf5 is offline   Reply With Quote
Sponsored Links
Old 05-19-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Engine Trouble, need intervention
im sure its possible. there are very little differences and the mounts/install should be the same. you will need a new EX ecu tho and will have to run the wire from the vtec solenoid (bolted to the engine) to the new ecu. be sure your new ecu is the same year and trans type (auto or manual) as your car.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 05-19-2009   #3 (permalink)
astroturf5
New Member
Thank you sooo much!!! One more question though, Where would you suggest looking for the new ECU and **what** would you suggest asking/looking for(specs on engine and ecu??)
Old 05-19-2009   #4 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Exactly what's dead? The engine or the transmission?
If you have a 2000 EX Civic then you already have VTEC. So you're options are to get a VTEC engine (D16Y8) or non-VTEC (D16Y7). If you get a Y8 then it's pretty much plug and play as long as it's a 99-00 engine. If you get the Y7 then you will need the Y7 (99-00) computer (P2E) otherwise you'll get a check engine light.
Now be careful - The 96-00 Civics came with D16Y7s and D16Y8s but the 96-98s are OBD2a and the 99-00s are ODB2b. The computer will be programmed either way and have different sized plugs. You have a 99-00 wiring harness so you need to stick with 99-00 parts. There are ways around this but if you're a car n00b you're better off keeping it simple and sticking with 99-00 parts.
sql_civic is offline   Reply With Quote
Old 05-19-2009   #5 (permalink)
astroturf5
New Member
The engine is the part that's toast...low oil pressure made it seize up I think. I don't think the car is VTEC because it's never kicked in(and there is no documentation from the dealership I bought it from that would indicate it was VTEC)
I am a car n00b, but I like to learn...
What exactly(like a list) would I need to put the VTEC into my car?
Old 05-19-2009   #6 (permalink)
sql_civic
Super Member
sql_civic's Avatar
Honda designed VTEC engines to not be noticable when when it kicks in.
So before you get going on how to add VTEC, be sure you don't already have it. All 2000 Civic EX 2-door coupes came with VTEC.
Look on the trunk on outside of your car. If there is an "EX" emblem on it then you have VTEC.
You can also look on the engine block for D16Y8 stamped in the front where is faces the radiator. It's down below where the upper radiator hose connects to the cylinder head.
I highlighted the stamp on my engine.
Another way to tell is to look for the VTEC solenoid on the cylinder head. It's just behind the distributor facing the firewall. It looks like this:
It's the part with the green plug on the bottom and the cylindrical part on top.
Old 05-19-2009   #7 (permalink)
astroturf5
New Member
ohh, I see! as soon as I get home I'll check. Thank you so much for all the help!
Old 05-19-2009   #8 (permalink)
lilmidget08
Member
lilmidget08's Avatar
lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned
Send a message via AIM to lilmidget08
if you have a factory sunroof then you have a ex.
lilmidget08 is offline   Reply With Quote
Old 05-25-2009   #9 (permalink)
kid1293
New Member
kid1293 is an unknown quantity at this point
wow that is a clean engine put it back in the crate
kid1293 is offline   Reply With Quote
Old 05-25-2009   #10 (permalink)
silver25civic
Member
silver25civic's Avatar
silver25civic is an unknown quantity at this point
i know a site that i go to to get all the engine codes and stock hp. here it is........http://www.superhonda.com/tech/honda_engine_codes.html
silver25civic is offline   Reply With Quote
Tags
2002 , 9600 , check , civic , code , codes , crv , cylinder , engine , forum , head , honda , intervention , stamp , starting , trouble
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
