| Re: transmission suggestions I'm a big fan of proper gear ratios and the LS does not have them for your engine. Screw the mileage talk, I still get 38MPG at ~80MPH (~4300 RPM) with my B16 and it's stock Y21 transmission.
The only thing that might help the LS is to put in a 4.40 final drive like the factory matched transmission. A stage 1 clutch is totally unnecessary. A lightened flywheel is never a bad investment but with the LS transmission's tall first gear it will be harder on your clutch as you slip it every time to get started from any stop.
My suggestion is to find a proper b16a transmission with LSD (or install one). By far the best upgrade for any transmission IMO, but I live for the corners/sweepers/esses. Especially in the wet.
