Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-19-2009   #1 (permalink)
PhilMize
New Member
PhilMize is an unknown quantity at this point
Suspension
I have a 97 civic dx. and I"m looking to replace my stock suspension thats dieing slowly on me. I only wanna spend around 400-450. Can anybody point me in the right direction? I'd like adjustables cause I wanna drop it an inch or so.
PhilMize is offline   Reply With Quote
Sponsored Links
Old 04-20-2009   #2 (permalink)
felix_2k1
New Member
felix_2k1 is an unknown quantity at this point
Re: Suspension
I think my eibach springs were around 350.00 if I'm not mistaken, They aren't adjustable but it dropped mine 1 1/2 inches.
felix_2k1 is offline   Reply With Quote
Old 04-20-2009   #3 (permalink)
felix_2k1
New Member
Re: Suspension
Go to buyeibach.com. Cheap
Old 04-20-2009   #4 (permalink)
ScottDR
Member
ScottDR will become famous soon enough
Re: Suspension
Adjustable coil-over types will cost much more than 4-500. If you still want a soft ride, go with a variable rate spring (like OEM) and a stiffer strut to make up for the stiffer spring.
If that's the route you are wanting to go, get some Eibach Pro-Kit springs (used to save money or around $200 new for a set). Then a set of KYB GR2 for about $72 each (or AGX for $99 each if you want to fine tune the ride to your liking). I'm sure there are plenty of other brands of struts that will also dampen those springs but most of my experience is with Koni's (read more $$$).
If you want something more the choices are limitless. Linear rate ERS springs (to the rate you want) on Ground Control coil-over sleeves is a good poor-man's version of full blown coil-overs as long as a good strut is used, like a Koni. Actual coilovers with linear rates can cost big money, but are really incredible.
ScottDR is offline   Reply With Quote
Old 04-20-2009   #5 (permalink)
ScottDR
Member
Re: Suspension
Oh, and if that's your car in the pic, nice DOHC and 99-00 front end swap
Old 04-20-2009   #6 (permalink)
lilmidget08
Member
lilmidget08's Avatar
lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned lilmidget08 should not be questioned
Send a message via AIM to lilmidget08
Re: Suspension
i have tenzo springs and stock struts. love the way it rides. lowers it more then a inch though. and my springs were only about 100 bucks
lilmidget08 is offline   Reply With Quote
Old 04-21-2009   #7 (permalink)
PhilMize
New Member
Re: Suspension
Quote:
yea thats me... thanx!
I was in a shop looking at some agx's they were like $390 something... they were the springs and shocks
I don't really know if thats a deal or not... I've never bought or looked into suspension before so im kinda learning as i go... I was looking on ebay at this tokico set http://tinyurl.com/dmzntk
also should I invest in a strut bar? rear and front? lower rear? I wanna get rid of wheel hop but I don't want to pay assloads of money for some stupid bar I could prob make from parts out of the junkyard...
Old 04-21-2009   #8 (permalink)
ScottDR
Member
Re: Suspension
Don't spend money on strut bars (unless you just buy the Si front one from Honda-it's cheap, light and works better than most). It will not help wheel hop at all. You just need good springs/struts. AGX's with springs for $390 new? That's the price of AGX's only new, so I'm not sure what kind of springs they would come with.
Linear rates are by far better for feel (heck and for wheel hop) but most people don't like them because they give a slightly harsher ride. On my track/fun car I could care less about ride quality, only turning corners with a linear compression/rebound. On my daily driver I have Eibach Pro-Kit's because a) I know the company (since I use ERS springs on my fun car) and b) I got them for $75 used. My stock struts aren't quite strong enough to firm up the ride though. I'll be tossing AGX's on but that may be overkill as GR-2's would probably do the trick but I also like the ability to fine tune the damping rates.
Old 04-21-2009   #9 (permalink)
ScottDR
Member
Re: Suspension
Oh...and watch out for AGX's on Ebay, KYB has warned that there are cheap knock-off's that come very close in appearance but aren't built with the same quality and you will have no warranty unless bought from an authorized dealer.
Tags
civic , honda , ride , soft , suspension
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
