Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-15-2008   #1 (permalink)
diamente
New Member
diamente is an unknown quantity at this point
Rust on bolts on exhaust manifold cover
What should I do with it? I am afraid if I spray WD 40 or other grease, it would catches fire because WD 40 and other grease are flammable.
diamente is offline   Reply With Quote
Sponsored Links
Old 11-16-2008   #2 (permalink)
Cleft_Asunder
Super Member
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light
Re: Rust on bolts on exhaust manifold cover
Quote:
Man if you're worried about rust on bolts then I hate to break it to you but you've got a whole can of worms to deal with. And what's going to light the wd-40 on fire? There's no way I can thnk of. And the kerosene in it evaporates within the hour or so.
__________________
'97 Civic DX 5-speed: Keyed to perfection.
http://www.civicforums.com/forums/signaturepics/sigpic34179_1.gif
Updated 96-00 timing belt DIY
Cleft recommends Raxles axles
Research the New World Order
Cleft_Asunder is offline   Reply With Quote
Old 11-28-2008   #3 (permalink)
97EXSweetSusie
New Member
97EXSweetSusie's Avatar
97EXSweetSusie is an unknown quantity at this point
Take some PB blaster to it and an air gun if u really need to or a breaker bar whatever u have a get those things off as long as u arent using a open flame to see under your car u are fine it will evaporate in a few mins and u will have no problems
__________________
1997 Honda Civic EX
1991 Camaro
97EXSweetSusie is offline   Reply With Quote
Old 11-28-2008   #4 (permalink)
Guso
Member
Guso's Avatar
Guso is an unknown quantity at this point
the best thing to do is get a tourch and heat it up. its the only way u can do it!
__________________
http://www.civicforums.com/forums/signaturepics/sigpic61788_3.gif
Guso is offline   Reply With Quote
Old 12-23-2008   #5 (permalink)
guachi
New Member
guachi's Avatar
guachi is an unknown quantity at this point
I sprayed bunches of WD 40 on mine and it never cached on fire, as the other member said it evaporates within a few minutes... should not worry about it...
guachi is offline   Reply With Quote
Old 12-23-2008   #6 (permalink)
JoshD
Member
JoshD's Avatar
JoshD will become famous soon enough JoshD will become famous soon enough
Pour Hydrochloric Acid all over it
__________________
RIDES
91 Accord Sedan H22 (Dead and gone)
-First car, RIP
05 Civic LX Sedan
-Auto and stock
I'm a sinner saved by grace. Put this in your sig if you are too.
JoshD is offline   Reply With Quote
Old 12-28-2008   #7 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Just spray it when it's cold.
sql_civic is offline   Reply With Quote
Old 12-28-2008   #8 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
rofl, rags should be a shop tool for everyone
04 Honda Civic is offline   Reply With Quote
Tags
2000 , 40 , 98 , bolts , civic , cover , covers , dx , exhaust , exhausts , honda , manifold , remove , rust , spray , spraying , wd
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
