Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-25-2008   #1 (permalink)
mrplow123456
Senior Member
mrplow123456's Avatar
mrplow123456 will become famous soon enough mrplow123456 will become famous soon enough
Overheating. HAs me stumped
Alright so the other day I was sitting in a parking lot with my car on listening to music and happened to look down and noticed my temp was hot, hotter then usual that is. I read around bc this is the first cooling problem I ever had and found that maybe the fan wasnt working.
I check one time and it wasn't on so I tried replacing the relay with another one. Then it came on. then I switched the relays again and it came on again. Now I just went for about a 3 hr drive and no cooling issues. It wasactually running cooler then normal maybe by a few degrees but still. I sat in a parking lot letting my car run and it startedheating up again. This time the fan was running. I have talked to plenty of people and they are stumped. Even the mechanics I've talked to.
Any suggestions? Its not realy a big deal if it only heats up in a paring lot. But this may lead to other problems. Thanks in Advance.
mrplow123456 is offline   Reply With Quote
Sponsored Links
Old 10-25-2008   #2 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
Re: Overheating. HAs me stumped
have u checked ur thermostat, a partially closed/open thermostat will act like this
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 10-25-2008   #3 (permalink)
mrplow123456
Senior Member
I eliminated the possiblity of th thermostat bc When Im riving it reman cool. from what I understand a faulty thermostat would cause overheat problems either at random or just all the time. I also tried to check by making sure the coolant was cycling around by feeling both rad hoses and both were warm. Maybe its weird and stops working when I sit. The other thing too is that with a bad thermostat wouldnt it take a while for the car cool once i start moving again? As soon as air starts flowing thru the car, as in me moving, it cools almost instantly.
Old 10-25-2008   #4 (permalink)
greeen01civic4d
balls in ur mouth
right, if it was half open, it could cause this, half open, half closed, blocking proper flow at idle, then waterpump kicks in when driving, sending more coolant through, its my only thought
__________________
Old 10-25-2008   #5 (permalink)
mrplow123456
Senior Member
Alright Ill have my mechanic check it out but i didnt wanna have anyone do it bc i dont have a lot o money. I may just get some buddies to do it. Any other thoughts if that doesnt solve it?
Old 10-25-2008   #6 (permalink)
Cleft_Asunder
Super Member
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light Cleft_Asunder is a glorious beacon of light
Dude, it's most likely your thermostat. Or thermo switch but you said your fan kicks in so it's not that.
__________________
'97 Civic DX 5-speed: Keyed to perfection.
http://www.civicforums.com/forums/signaturepics/sigpic34179_1.gif
Updated 96-00 timing belt DIY
Cleft recommends Raxles axles
Research the New World Order
Cleft_Asunder is offline   Reply With Quote
Old 12-10-2008   #7 (permalink)
mrplow123456
Senior Member
UPDATE: Just replaced my thermo and the heating issue not only went away but it only takes about 2 - 3 mins to heat up now. Thanks a lot everyone. Another problem I had was so that my car wouldn't overheat, I would let it run til it got hot then shut my car off. But when I went to turn my car on, the battery would be dead. I bought a new Optima and loving it. No more problems and the battery lasts twice as long when I run it dry. Hopefully this helps everyone.
Old 12-10-2008   #8 (permalink)
greeen01civic4d
balls in ur mouth
glad it worked out!
__________________
Old 12-10-2008   #9 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
yeah i need to do thermostat too. my car is starting to take much longer to warm up.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 03-03-2009   #10 (permalink)
chocosteve
New Member
chocosteve is an unknown quantity at this point
Awesome, you were having the exact same problems as my Civic is having. Hopefully just a thermostat will be the nice and inexpensive fix I am looking for. Thanks!
chocosteve is offline   Reply With Quote
Old 03-03-2009   #11 (permalink)
mrplow123456
Senior Member
Hopefully that is all you need. Just make sure after you replace the thermostat that you top off your antifreeze and remove all air bubbles from your coolant. If you don't, it is possible to have problems that seem worse then before you replace the thermostat. Good Luck.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
