Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-04-2008   #1 (permalink)
imglowin
New Member
imglowin is an unknown quantity at this point
Post Disappearing oil and coolant 96' civic LX
Hi, I have been looking at this forum for quite some time but have never needed to post thanks to all of the previous responses to other threads. I like doing repairs on my own car but I am still learning quite a bit so any help would be greatly appreciated.
coolant; I have to top off or refill the radiator it seems every 3-4 days because I will notice the temperature gauge going up past it normal range. I have replaced the thermostat thinking that it was the problem but to no avail I'm still having issues. I am not seeing any leaking indications on the ground or within the engine after driving or even from it just sitting at night.
oil; similar to the coolant, I have to refill that about every 1-2 weeks. There are no spotting or leak indications on the ground after driving or from just sitting. I have made sure the oil filter is on tight(of course not cranked on) and that the drain bolt is on securely.
I'm really stumped so if anyone could help. Thanks!
imglowin is offline   Reply With Quote
Sponsored Links
Old 10-04-2008   #2 (permalink)
screwface
New Member
screwface is an unknown quantity at this point
Re: Disappearing oil and coolant 96' civic LX
your engine could be burning away both if your head gasket is farked. if you like doing your own work, you're gonna love replacing that
screwface is offline   Reply With Quote
Old 10-04-2008   #3 (permalink)
imglowin
New Member
Ok, that's possible. My engine overheated last summer and I had to have the radiator, radiator hoses, t stat replaced. How can I check the "farkness"?
Old 10-04-2008   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
you gotta take the head off, then take it to machine shop to get it checked for warpage, compression tested, etc. then replace the gasket when you put it back together
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 10-04-2008   #5 (permalink)
imglowin
New Member
how easy/difficult would it be to take the head off? and are there any online step by step directions that anybody knows of of how to do it?
Old 10-04-2008   #6 (permalink)
gearbox
Super Moderator
you need the honda service manual, and its not an amateur job. two guys who did it before took all day to take mine off and there were problems along the way too. if you dont know anything about it, including what all parts and fluids and torque specs and what to check when its off, i wouldnt do it yourself. there is alot to mess up and lots of places to get stuck and possibly ruin something further.
__________________
www.lubecontrol.com
Member 1025782
Old 10-05-2008   #7 (permalink)
screwface
New Member
need a helm's manual for sure. also need to buy head gasket, ARP headstuds (cheaper than OEM iirc; and reusable too unlike OEM) and a crank pulley holder tool (50mm hex iirc.) if you're doing so much then yeah may as well have the head resurfaced for additional 100 bux or so.
i've seen some pictorials online but i don't have the links. the hardest part will be busting the crank pulley loose. i'm thinking if you jack your car up, a pneumatic impact wrench will be the only way to go because unless you're the incredible hulk a suitable breaker bar on any ratchet will flex more than the distance that any floor jack can raise the car to.
probably best off taking it to a shop...
Old 10-07-2008   #8 (permalink)
imglowin
New Member
thanks everybody for your input. I don't think am ready to dive this far into it nor do I have the time it sounds like it would require, so I am gonna let a car shop do the damage.
Tags
50 , 96 , attachment , burning , civic , coolant , disappearing , fluid , hex , holder , honda , mm , pulley , radiator , vtec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
