| Re: 1999 Honda Civic CXi too noisy!!! help!!!!!! it might be just a simple squeaky belt. are they all tightened properly? check the muffler and pipes for corrosion. even a small hole will make tons of noise. also check where the header bolts to the engine for leaks around the gaskets.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring. |
