Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-09-2008   #1 (permalink)
thesob40
New Member
thesob40 is an unknown quantity at this point
helicoil
hey guys. When i was changing my oil the other day i noticed that the threading on the oil pan was stripped which is causing the oil to leak out slowly through the bolt...i dont feel like replacing the oil pan itself because and new oem one runs around 100 bucks. Any idea where i can find a helicoil that will fix this problem? ive searched all local autopart stores and online and cant seem to find anything. Any help would be appreciated. To remove this ad, register today for free or log in if already registered!
thesob40 is offline   Reply With Quote
Sponsored Links
Old 06-10-2008   #2 (permalink)
hondaex08
New Member
hondaex08 is an unknown quantity at this point
Re: helicoil
u can find that kit at most auto parts stores or even an harbor freight store . but from one tuner to another i suggest you spend the 100 $ it will be worth it in the long run . b cause every time you go to change your oil you have to remove that plug and a helicoil will not stand up for it . in the long run its worth the money or even check out ebay for a good deal on a oil pan
hondaex08 is offline   Reply With Quote
Old 06-10-2008   #3 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Re: helicoil
partstrain.com or http://www.hondaautomotiveparts.com/
TRIZ is offline   Reply With Quote
Old 06-11-2008   #4 (permalink)
thesob40
New Member
Re: helicoil
new oil pan it is then. thanks.
Old 06-11-2008   #5 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: helicoil
we carry them at advance auto parts in special job tools section.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 06-14-2008   #6 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Re: helicoil
x2 on replacing the pan. But you'll need a new gasket as well so the price goes up.
sql_civic is offline   Reply With Quote
Old 4 Weeks Ago   #7 (permalink)
deadair
New Member
deadair is an unknown quantity at this point
Re: helicoil
Here's the result of a "professionally installed" helicoil. Set me back over $350 and IMMEDIATELY resulted in more damage than before it was "installed."
deadair is offline   Reply With Quote
Old 4 Weeks Ago   #8 (permalink)
gearbox
Super Moderator
Re: helicoil
wow haha. helicoils are good but youre not supposed to use em like that! its for mild repairs that arent under any pressure. i used one on my seat bolt but it can come out pretty easily if i wanted to remove it. whoever did that must be a complete retard. im guessing you got a new head put on?
__________________
www.lubecontrol.com
Member 1025782
Old 4 Weeks Ago   #9 (permalink)
deadair
New Member
Re: helicoil
Quote:
My understanding is that helicoils can be legitimately used in sparkplug holes. I'm not familiar with the installation procedure, but suspect it's best done with the head off and by a shop.
Anyway, I've ordered a remanufactured head from an Ebay store. Pretty good deal: $230 and no core charge.
http://motors.shop.ebay.com/elnieves...1&_from=&_ipg=
Old 4 Weeks Ago   #10 (permalink)
gearbox
Super Moderator
Re: helicoil
there is no way the coil will stay put in an engine. usually threadlock is used to hold them in place, and even that is not a pernatent solution but its usually okay for normal applications. i wonder how many metal shavings got into the engine and caused even more damage when he did that first repair. i know when i did my seat bolt, i had a huge mess of shavings all over the floor from tapping.
__________________
www.lubecontrol.com
Member 1025782
Old 4 Weeks Ago   #11 (permalink)
deadair
New Member
Re: helicoil
Yeah, that was my concern too. However, I didn't see any unusual residue in the combustion chamber (other than the helicoil, of course), so I guess the shop at least did that part right.
Old 3 Weeks Ago   #12 (permalink)
SatyaK
New Member
SatyaK is an unknown quantity at this point
Re: helicoil
You can find all helicoil tools & thread repair kits on
http://www.helicoil.in
SatyaK is offline   Reply With Quote
Tags
1997 , advance , auto , change , civic , helicoil , honda , kit , leak , oil , pan , replacement , solenoid , stripped , valve , vtec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
