Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-24-2008   #1 (permalink)
Vertigo Jones
New Member
Vertigo Jones is an unknown quantity at this point
Minimum engine modifications to mount a turbo
Chewing through everything I can find to see what can actually be done to to a D series SOHC VTEC, the most common suggestion is "get a different engine", However, one thing I have found is that both Turbo and supercharger kits are available that would "fit". However, therea a big stumbling block.
The D15Z6 has very little in the way of upgrades for Rods, cams, pistons or anything else, So, my query is this :- Just how bad is fitting a turbo or SC when retaining most of your stock engine innards?
Vertigo Jones is offline   Reply With Quote
Sponsored Links
Old 06-14-2008   #2 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Re: Minimum engine modifications to mount a turbo
You can keep your stock innards if you stay below 200 HP.
sql_civic is offline   Reply With Quote
Old 10-08-2009   #3 (permalink)
jimbolina25
New Member
jimbolina25 is an unknown quantity at this point
do you need to reprogram the ecu to fit a turbo?
jimbolina25 is offline   Reply With Quote
Old 10-08-2009   #4 (permalink)
OCDjG
Member
OCDjG will become famous soon enough
Quote:
You definitely want to get some kind of tuning control with your turbo. Check out this forum here...
http://www.d-series.org/forums/
You'll find all the info you need there.
OCDjG is offline   Reply With Quote
Tags
01 , 10 , 2000 , 2004 , 2006 , 98 , civic , engine , honda , modification , mods , motor , put , stch , top , turbo , upgrades
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
