Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-21-2008   #1 (permalink)
Kojak
New Member
Kojak is an unknown quantity at this point
Question Civic sitting crooked
I had noticed for a while that my 1996 civic was sitting kinda crooked. The passenger front had the biggest gap between the tire and fender and the drivers side rear was the lowest. I replaced the shocks and springs and nothing changed. So I replaced the bushings in the rear and still nothing. What am I missing? Any input would be greatly appreciated! To remove this ad, register today for free or log in if already registered!
Kojak is offline   Reply With Quote
Sponsored Links
Old 04-22-2008   #2 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Re: Civic sitting crooked
Check that the ball joint on the LCA is properly installed and the the UCAs aren't shot.
sql_civic is offline   Reply With Quote
Old 04-23-2008   #3 (permalink)
Kojak
New Member
Hey thanks for the reply, but please pardon my ignorance. What ball joint are you refering to, and what is a UCA?
Old 04-24-2008   #4 (permalink)
sql_civic
Super Member
sql_civic's Avatar
UCA = upper control arm.
There's a ball joint in the lower control arm that connects to the steering knuckle. It could possibly be not fully seated. The UCA ball joint could be pressed out of it's fitting if it's really messed up.
Old 04-25-2008   #5 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all
Send a message via AIM to tuningmycivic Send a message via Yahoo to tuningmycivic
and i think he's referring to the front lower control arm (LCA). not sure which side, but i would have it all checked out. you may also have a blown shock on the driver's side rear.
__________________
T.E.A.R.S. Member #5 All turbo builds end in T.E.A.R.S
My turbo build thread 169.39 WHP/157.15 WTQ
Quote:
Originally Posted by TRIZ View Post
you cant just add a k20 to a car like an extra plastic brick to your lego people house.
“Great pain is, as the teacher of great suspicion, the ultimate liberator of the spirit.” - Friedrich Nietzsche as quoted by Mark Twight of Gym Jones
tuningmycivic is offline   Reply With Quote
Old 04-30-2008   #6 (permalink)
clkelly
New Member
clkelly is an unknown quantity at this point
I also have a 96 civic doing the same thing. I don't think that a shock would cause the car to sit lower. It would seem that the spring would control the height. I am in the process of replacing my springs. Will probably at that time look at the bushings, as they are squeeking some now.
If anyone has other ideas let's hear them.
clkelly is offline   Reply With Quote
Old 04-30-2008   #7 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
Are you sure your springs are the same size all the way around? If someone half assed a repair, it could cause this.
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Old 04-30-2008   #8 (permalink)
Kojak
New Member
Hey guys thanks for the replies. I went out today and checked it out... all the joints and stuff are fine. The springs are Tein H-tech's, which I installed myself... so they are definitely all the same height. I still don't get it... starting to really bug me...
Old 04-30-2008   #9 (permalink)
ONE7thREBUILT
Senior Member
ONE7thREBUILT's Avatar
ONE7thREBUILT has a spectacular aura about ONE7thREBUILT has a spectacular aura about
Maybe the frame is twisted.
ONE7thREBUILT is offline   Reply With Quote
Old 05-01-2008   #10 (permalink)
Kojak
New Member
Yikes! How do I tell if the frame is actually twisted?
Old 05-01-2008   #11 (permalink)
ONE7thREBUILT
Senior Member
Park on a very flat surface and measure the distance from frame to ground at different spots on each side and compare.
Old 05-01-2008   #12 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
or goto a bodyshop lol
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
