Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-22-2007   #1 (permalink)
mnea
New Member
mnea's Avatar
mnea is an unknown quantity at this point
Power Window issues on my 96 EX
I am having the following power window issues on my 96 EX:
1) My front passenger side window will not open at all. When I try using the passenger side switch nothing happens. It kinda moves like it wants to open but doesn't when I try using it's switch on the driver side.
2) My front driver side window has come out of track and won't close properly.
How do I take off the front door panels and what am I looking for to troubleshoot these issues when I do?
Thanks!
mnea is offline   Reply With Quote
Sponsored Links
Old 09-22-2007   #2 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Re: Power Window issues on my 96 EX
Have you found the free OEM service manual floating around the internet ?? It has a lot of info required.
You may have binding of the window that does not want to move. The one off track, I cant say.
CraigW is offline   Reply With Quote
Old 09-26-2007   #3 (permalink)
mnea
New Member
mnea's Avatar
I have the Honda service manual but can't really figure out how to take off the front door panels.
Old 09-26-2007   #4 (permalink)
CiViCPrAnInG2k1
CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned
Send a message via AIM to CiViCPrAnInG2k1
search ebay... sometimes they have manuals. if that's not the case, maybe you could go to a Honda dealer and request for one?
CiViCPrAnInG2k1 is offline   Reply With Quote
Old 09-28-2007   #5 (permalink)
juan_p__m
New Member
juan_p__m is an unknown quantity at this point
Send a message via MSN to juan_p__m
- remove handle cover, pry were you will se a tab
- after cover you will see bolts for handle assy, remove them, disconnect window switch assy
- remove speaker cove and speaker
- you will need a clip remover, carefully bry at clips that hold door panel in place and then pry panel up and out.
juan_p__m is offline   Reply With Quote
Old 09-28-2007   #6 (permalink)
juan_p__m
New Member
Here is the OEM manual on the door panel removal
Old 10-05-2007   #7 (permalink)
mnea
New Member
mnea's Avatar
Thanks for the help...I really appreciate it!!!
I got the passenger side door panel off and here's the deal...When I try using the passenger side power window switch (on the passenger side) to open the window nothing happens except in the close position, the window kinda moves upwards but it's already closed and has no room to move. However, when I use the switch on the driver's side, all the windows work except the front passenger side, which does not move at all in either the open or close position. What could be the problem here?
Old 10-05-2007   #8 (permalink)
CraigW
Platinum Member
CraigW's Avatar
With the car engine off and key in # II position and dome light on... Look for slight dimming of the dome light while attempting troubled window. ( no dimming may mean voltage not reaching motor, dimming using up and down may indicate window is binding)
Trying to narrow to electrical or mechanical problems.
Old 10-05-2007   #9 (permalink)
mnea
New Member
mnea's Avatar
Slight dimming occurs when I use the passenger side switch to try to close the window and the window moves slightly upwards but is already closed.
Dimming does not occur when I use the passenger side power window switch to try to open the window and it does not move; nor when I use the driver's side switch to attempt opening and closing the passenger side window and it does not move.
Old 10-05-2007   #10 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Sounds electrical, One other no cost test would be to substitute one of the back switch assemblies for the front passenger switch assembly. ( the master switch can also cause similar symptoms) Do you have a meter or 12 volt test lamp available ??
Old 10-06-2007   #11 (permalink)
mnea
New Member
mnea's Avatar
OK...I tried one of the working back door switch assemblies on the front passenger side and the same exact problem occurred. When I try to open the window nothing happens except in the close position, the window kinda moves upwards but it's already closed and has no room to move.
Anyone have any ideas???
Old 10-07-2007   #12 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Good luck. Hang in there, you'll figure it out.
I once had my power windows stuck in the closed position on the hottest day of the year when the A/C was also busted. I swore off power windows from that day on. It was not a Honda.
sql_civic is offline   Reply With Quote
Old 10-08-2007   #13 (permalink)
mnea
New Member
mnea's Avatar
The only thing I could figure out at this point is that it's most likely NOT the power window switch. What confuses me is why if I try to open or close the passenger side window with the driver's side master switch (on which all other switches work) it will not move at all. But when I try it's own switch the window does move slightly upward when I try to close it...but it's already closed and doesn't really have any room to move. This happened even when substituting a working switch from the rear door.
If not the power window switch, what else could make this happen?
Old 10-15-2007   #14 (permalink)
mrplow123456
Senior Member
mrplow123456's Avatar
mrplow123456 will become famous soon enough mrplow123456 will become famous soon enough
I'm not quite sure if you tried this yet, don't yell at me if you have, but have you made sure that the window lock is off. I sat in my car for an hour one day because my hand bumped it by accident. Just a thought.
mrplow123456 is offline   Reply With Quote
Old 10-16-2007   #15 (permalink)
mnea
New Member
mnea's Avatar
mrplow, Thanks but yes, I checked that early on...Anyone else have any ideas?
Tags
1996 , 1997 , 97 , car , civic , cost , cover , door , fixing , front , honda , power , problems , remove , speaker , stuck , window , windows , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
