Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-09-2008   #31 (permalink)
mnea
New Member
mnea's Avatar
mnea is an unknown quantity at this point
Re: Power Window issues on my 96 EX
Thanks CraigW! To remove this ad, register today for free or log in if already registered!
mnea is offline   Reply With Quote
Sponsored Links
Old 07-30-2008   #32 (permalink)
hufe01
New Member
hufe01 is an unknown quantity at this point
TSB #97-021
Will Honda Dealer fix this for free? I have the exact same issue.
hufe01 is offline   Reply With Quote
Old 07-14-2009   #33 (permalink)
jbsf
New Member
jbsf is an unknown quantity at this point
So did you ever resolve the issue with your passenger window? I've got the EXACT same issue, and I can't figure it out!
jbsf is offline   Reply With Quote
Old 07-15-2009   #34 (permalink)
DeesFooda
New Member
DeesFooda is an unknown quantity at this point
Pharmacy no prescription
propecia drug, propecia in women - need propecia. propecia without a prescription, lowest propecia 1 mg propecia before and after picture. propecia prescription canada - acne propecia, en francais propecia. online order propecia. propecia by mail. cheap propecia online.
buy propecia now, reviews of propecia. canada generic propecia. ...Thanks
DeesFooda is offline   Reply With Quote
Old 09-08-2009   #35 (permalink)
mathias
New Member
mathias is an unknown quantity at this point
Quote:
jbsf and op, did either of you resolve this issue? My '98 HX is the same -- master switch does nothing (with or without the window lock on), and the passenger switch will only go up. Checking with a voltmeter, I got no power using the master switch. Using the passenger switch, I got the following results:
blue/white is ground w/no switches pressed, and while in the up position. In the down position it is +12.
blue/red is +12 in the up position, but is NOT ground in the down position.
Is there a power window control module in these cars?
mathias is offline   Reply With Quote
Old 09-08-2009   #36 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
You should measure the voltage at the leads going to the problem window's motor (sorry I do not know the wire colors on this generation) The polarity between the 2 wires should reverse for the up / down operation.
You can also apply voltage to the disconnected motor to see if it moves (you may need to reverse polarity)
CraigW is offline   Reply With Quote
Old 09-08-2009   #37 (permalink)
mathias
New Member
Thanks. Yeah, that is what I did. I disconnected the motor and checked for voltage and ground on each wire. In the direction that works, I get +12 on one wire and ground on the other. In the other direction, I get +12 on the correct wire, but no ground on the other. So, that would sound like a bad ground, but I need a circuit diagram to trace out the ground. I assume I have to trace it through the switch and door, and into the car somewhere.
To give a little more background, my car doors had a few dents when I got it. The passenger window worked at that time, but the regulator was shot. I got the window rolled back up, but then it wouldn't roll down again. I'm guessing during the process of rolling the window back up I blew a fusible link, or a control module if there is one, or ???
I installed the 2nd set of doors and the problem persists. So, I have swapped master switch, passenger switch, door wiring on both sides, motor and regulator. My theory is that the problem does not exist in the doors. There is a broken module, control, relay, fusible link, ground connection inside the car, or broken wire in the door jamb. But, if the same symptoms are on three different cars, I don't think it is a broken wire.
Thanks for any insight. If someone has an electrical diagram, that would be great.
Old 09-08-2009   #38 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Here is the wiring info, It looks like the factory schematic hth.
Old 09-08-2009   #39 (permalink)
mathias
New Member
Thanks a lot! So, there is a control unit, but it is built into the master switch, and only deals with the driver's window, which works fine. Armed with this diagram, I'll check out the car in the light tomorrow, and let you know what I find.
Old 09-08-2009   #40 (permalink)
mathias
New Member
Switches on both sides ohm out correctly -- they are not the problem. Unplugged both switches, and checked continuity from plug to plug. The blue/orange wire is continuous, but the blue/yellow is not. Stranger than that, the blue/yellow wire has +12 on it on the passenger plug (w/ ignition on)! Guess I'll start tracing that wire in the daylight...
Just looking at the symptoms and the diagram, if either of those wires are broken, you will get the symptoms of the master switch does nothing, and the secondary switch will only work in one direction.
Old 09-09-2009   #41 (permalink)
CraigW
Platinum Member
CraigW's Avatar
The control unit is for the "auto down"
Make sure both black wires from the master switch are making good ground connections.
Have you tried another master switch ??
Old 09-13-2009   #42 (permalink)
mathias
New Member
Of course I started at the wrong end, but I found and fixed the problem this evening. In case any one needs to know, the door wiring goes down through the front quarters, through the door sills, and under the seats. I did not see any connectors all the way through the car.
My problem was the connector to the driver's door. I pulled back the rubber boot, and four wires were loose. Apparently the window wire was hitting a power wire occasionally, which was why I had +12 on it one time.
Fortunately I had pulled the connector when I bought the set of doors from the junkyard, so I was able to splice and solder on the new connector. The side benefit is that my speakers sound much better.
Tags
1996 , 1997 , 97 , car , civic , cost , cover , door , fixing , front , honda , power , problems , remove , speaker , stuck , window , windows , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
