Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-16-2007   #16 (permalink)
mnea
New Member
mnea's Avatar
mnea is an unknown quantity at this point
Re: Power Window issues on my 96 EX
Quote:
Originally Posted by CraigW View Post
With the car engine off and key in # II position and dome light on... Look for slight dimming of the dome light while attempting troubled window. ( no dimming may mean voltage not reaching motor, dimming using up and down may indicate window is binding)...
Dimming did occur...if the window is binding, can you or anyone else expand on how to confirm and fix this type of problem?
mnea is offline   Reply With Quote
Sponsored Links
Old 10-18-2007   #17 (permalink)
RonJ
New Member
RonJ is on a distinguished road
Regarding the problem with the front passenger power window, it's pretty clear that the switch is fine. Based on all the information, I believe that the likely culprit is the front passenger window motor. I had to replace two such window motors in a 1998 Toyota Sienna, and the symptoms were very similar to those you have described.
The attached file describes how to test a Civic passenger window motor for defects. I hope this information helps.
By the way, did you figure out the problem with the front driver window?
RonJ is offline   Reply With Quote
Old 10-18-2007   #18 (permalink)
Nitro Express
Member
Nitro Express is an unknown quantity at this point
Sounds like your window motor might be bad. I had the exact same kind of problem on my wifes minivan. I even took the motor out and put power to it. Wtih no load it worked fine, as soon as I put load on it, it stopped. BTW a cheap Volt-Ohm meter comes in handy. You can pick one up at radio shack for about $15.00. Good luck.
Nitro Express is offline   Reply With Quote
Old 10-19-2007   #19 (permalink)
mrplow123456
Senior Member
mrplow123456's Avatar
mrplow123456 will become famous soon enough mrplow123456 will become famous soon enough
Is it possible that the passnger motor is blown? With the driver side window, go out and buy a 20 dollar Hayne's manual, it comes in handy, and it tells you how to remove the panels. Realign the track and you should be good.
mrplow123456 is offline   Reply With Quote
Old 10-21-2007   #20 (permalink)
mnea
New Member
mnea's Avatar
Quote:
Originally Posted by RonJ View Post
...The attached file describes how to test a Civic passenger window motor for defects. I hope this information helps.
Thanks Ron, posting that file was very thoughtful. Step 3 kind of confuses me however, It says to check window operation by connecting power and ground according to table. Excuse my ignorance but I'm not really sure how to do that.
Not yet...it seems to be kind of loose or off the track. It appears to be aligned properly but then on the way up it ends up outside the rubber stripping and will not close. However, I can pull it inwards a little on the way up and get it to align properly and close.
Old 10-21-2007   #21 (permalink)
mnea
New Member
mnea's Avatar
Quote:
Nitri, Thanks for the reply. Your wife is a very lucky woman to have a man like you around to help her. Once again, please excuse my ignorance but can you please explain what no load vs load means, what a "Volt-Ohm meter" is and how to use it to help me in this situation?
Old 10-21-2007   #22 (permalink)
mnea
New Member
mnea's Avatar
Quote:
I've got the Honda service manual and have become familiar with removing the panels at least on the front and rear passenger side doors with a little help from my friends here...especially juan_p__m...Thanks again! However, I can't seem to find anything on realigning the front driver's side window properly in it's track. Is the Hayne's manual more helpful than the Honda service manual?
Old 10-21-2007   #23 (permalink)
RonJ
New Member
I'll do my best to explain the motor test and the good suggestion made by Nitri Express.
The motor test illustrated in the picture I posted tells you to bypass the power window switch on the door by disconnecting the 2P connector and then to provide a separate 12V power source directly to the window motor. The motor should move the window up or down depending on the polarity of the + or - wires from the power source to the 2P connector. If the window motor does not operate as expected, then it should be replaced.
Nitri Express' suggestion (I believe) is that you also verify that the power switch is working properly by disconnecting the 2P connector and showing that you detect proper voltage from the switch-side of the 2P connector when you press the power window switch in either the up or down position. The tool used to perform this simple test is an inexpensive Multimeter that you can purchase from any hardware store. The answer about load vs no-load is testing window motor operation when the motor is either moving a window (load) or disconnected from a window (no load).
With all this said, I believe that the motor is likely your problem. To test this, you could also purchase a replacement motor from your local auto parts chain (carefully unpackage and save all packaging in case you need to return part) and install it. If the window now works, then you are done. If the window does not work (unlikely), return for a refund and simply tell them that the part was not needed.
Your other problem with the driver window alignment is likely the regulator. Check for any loose or broken parts. Comparing operation of the driver and passenger side regulator may help you figure out the problem.
Old 10-21-2007   #24 (permalink)
RonJ
New Member
By the way, here is a picture of the window regulator in your door:
Old 10-22-2007   #25 (permalink)
Nitro Express
Member
Exactly RonJ
Old 02-19-2008   #26 (permalink)
meangreen
New Member
meangreen is an unknown quantity at this point
some other things it could be...
first, with the driver door, go to an autoparts store and get some silicon spray lube! the reason it keeps coming off the track is because the track needs lubed! make sure you use silicon spray lube because regular greese wont work.
the passenger window? have you checked the wiring from the chassis to the door? there is a plug there, you should make sure you dont have any severed wiring - i did, i fixed it, now my windows and power locks work great.
also again with the pasenger window, use the silicon lube again, you might be having a problem with friction!
meangreen is offline   Reply With Quote
Old 06-22-2008   #27 (permalink)
mnea
New Member
mnea's Avatar
Quote:
Originally Posted by Nitro Express View Post
...BTW a cheap Volt-Ohm meter comes in handy. You can pick one up at radio shack for about $15.00. Good luck.
At Radio Shack they come in different "ranges" such as "8 range", "15 range", "17 range", etc...What's the meaning of the range rating and which Volt-Ohm meter is recommended for the money?
Old 06-23-2008   #28 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Quote:
Just a basic meter will do, I would go with the DMM type. Mainly for voltage and resistance checks. Some have continuity beep.
To keep it safe be sure of meter setting before test, Never apply voltage when set into resistance or current mode.
Another good tool for voltage checks is a 12 volt test lamp from the auto parts store.
CraigW is offline   Reply With Quote
Old 07-09-2008   #29 (permalink)
mnea
New Member
mnea's Avatar
What is DMM?
Old 07-09-2008   #30 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Digital Multi Meter.
Tags
1996 , 1997 , 97 , car , civic , cost , cover , door , fixing , front , honda , power , problems , remove , speaker , stuck , window , windows , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
