Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-17-2007   #1 (permalink)
jkkim0
New Member
jkkim0 is an unknown quantity at this point
Send a message via AIM to jkkim0
98 civic coupe window problem
My 98 civic coupe hx has encountered a problem with the passenger side window causing it to get stuck every time i put my window up. I just went to the mechanic and told it it was out of place and he recommended me that I would have to buy a new regulator? Has this happened to your civic and how did you fix the problem? If no solution then Ill just pay for them to fix it. thanks -jason To remove this ad, register today for free or log in if already registered!
jkkim0 is offline   Reply With Quote
Sponsored Links
Old 07-28-2007   #2 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Re: 98 civic coupe window problem
This happened to my 97 Civic only on the driver's side.
I fixed it by taking off the door panel, removing the regulator, and lubricating the moving parts with white lithium grease. There was one part that was binding up. After lubing it up it's work fine for the last 5 years.
sql_civic is offline   Reply With Quote
Old 08-08-2007   #3 (permalink)
photomercenary
New Member
photomercenary's Avatar
photomercenary is an unknown quantity at this point
This sounds like my 97 EX a few years ago... the windows were getting sluggish the colder the weather got and by the time winter arrived they rolled down real slowly and barely made it back up without "help" from my hand pushing upward on the glass.
One day when I brought the car in I mentioned it to the mechanic and he lubed them up a bit. Much better after that, but still not as fast as when I first got the car.
photomercenary is offline   Reply With Quote
Old 2 Weeks Ago   #4 (permalink)
ryanreaction
New Member
ryanreaction is an unknown quantity at this point
This is the same problem that I have with my 97 EX. Both the drivers side window and the front passenger window are sluggish. My friends 96 is the same way. Do all Civic during these years have this problem? I replaced the regulator, the motor and the switch and and the window is still sluggish. What parts should I lube? Thanks!
Help detour people from drunk driving. Post your drunk driver story here:
Drunk Driving Stories
ryanreaction is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
