Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-03-2007   #1 (permalink)
FerioRallyB16a
New Member
FerioRallyB16a is an unknown quantity at this point
How Much HP will N/A B16a make..?
i m looking to go N/A on usdm b16
w/ valves, V springs, retainers,some gsr valves, cam gears and shafts
which combinations(brand) are known to make GOOD HP...?
thank you
FerioRallyB16a is offline   Reply With Quote
Sponsored Links
Old 04-03-2007   #2 (permalink)
FerioRallyB16a
New Member
Re: How Much HP will N/A B16a make..?
let me get the question more details..
how much punishment can OEM gsr valves n springs take..?
what type of shafts is best(has just enuff power so i don damege internals) for gsr valves/springs..?
thank u
Old 04-06-2007   #3 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Wrong forum for this question. You're not likely to get B16 experts visiting here as the 6th Gen Civic uses D16 engines.
sql_civic is offline   Reply With Quote
Old 04-30-2007   #4 (permalink)
elusive_da
New Member
elusive_da is an unknown quantity at this point
i just sold my 90 integra (DA) 4dr. with a b16 swap, this is what i did
head & intake manifold port and polish, JE frogger throttle body, type-r cams, every moving part from the head gasket up was changed to type-r, dc header w/ drag heat wrap, full 2 1/4 inch straight pipe header back exhaust, injen cold air intake w/ arospeed mushroom filter, i converted from obd-0 to obd-1 for better tuning, ive always noticed that obd-1 is better than obd-0 or obd-2a/b to tune, vtec controller, ballenced pistons rods and crank, this made it so i could get light weight pullys and balencer because there was no vibration, msd ignition, i put in b20 injectors but i dont know if it made a diff., AEM fuel rail and regulator, type-r water pump, a chipped ECU and a chrome valve cover lol, thats all that comes to mind and i had the 160hp 111tq at the flywheel b16 and i got it to 197hp 134tq of 100% untuned power to the ground and i could rev to 10,000 but i never did, id take it to 9000ish and got scared because i put to much $ in it to blow it up but the kid i sold it to bounces off the rev. limiter all day long and all he had changed was the cam seals...., i got pics via myspace search e-mail mrkevindshore@yahoo.com
this is my repost.... i hope it helps
elusive_da is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
My new 4th gen hatch
Shifting problem, won't go into gear
96-00 ex rear disc conversion?
Power Window issues on my 96 EX
Tire Size
Turbo Kit for D16Y8 (44K miles)
97 Civic RPM Fluctuation when Driving
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
