Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen Honda Civic
6th Gen Honda Civic In the years from 1996 to 2000 Honda released it's 6th Generation Honda Civic. This Honda Civic had a more aggressive front end and overall body style. It was an instant hit among import tuners.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-02-2005   #1 (permalink)
markciotti
New Member
markciotti will become famous soon enough markciotti will become famous soon enough
Used factory radio installation for 96 Civic ex
Hi, I'm new to this site so I hope I'm in the right section for this question.
I purchased a used 96 Honda Civic Ex 2 years ago and have had problems with the keyless remote. I mindlessly thought the one's I had were damaged so I shelled out the $100 for a new factory remote. I had the same problems with the new remote. I've been told this make and model/yr of the civic is the only one that routes the remote door lock through the FACTORY radio.
My radio works fine but upon attempting to re-activate the remote I only heard a mild thump from the passenger door instead of the click from the drivers side. Honda and my mechanic told me it was most likely the actuator or actuator switch. After having my mechanic remove the door panel (another $40) he said my actuator and switch were working fine and it's definitely a problem with the radio. After talking to several Honda parts reps I've now been told that I can use the factory radio from any civic model from 96 to 98 to replace mine and that would allow me to use my remote door lock again. (a new one from Honda is over $600) I have been able to purchase a used one locally and have several questions. (bet you thought I'd never get to the question, LOL)
Is there a way to test the used radio I purchased to see if it actually works prior to installing it?
I'm assuming all my cables connectors are working on my current factory radio, but should I purchase new cables/connectors when installing the other radio?
And last but not least, How do I install the radio? Do I need any special tools?
Thanks for any information anyone can give me. I'm about ready to crush the remote and resign myself to using the keys from now on. LOL
markciotti is offline   Reply With Quote
Sponsored Links
Old 07-03-2005   #2 (permalink)
AdmireMyGr8ness
Retired SuperMod
AdmireMyGr8ness's Avatar
AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future AdmireMyGr8ness has a brilliant future
I have a question or two...
Did your stock radio work at all prior to getting the new one?
Are you concerned that the new radio you purchased won't work in your car b/c of what?
Do you have a non-factory HU installed as well?
Here's some answers to your questions...to the best of my knowledge.
You should be able to test it by connecting the wiring harness to the new radio before installing...
Installing the radio...mine was shoved down in behind the console where my current HU is now as I needed it for my keyless entry as well.
You shouldn't need any special tools as far as I can remember.
I'm gonna send one of our I.C.E. experts here to see if they can answer your questions better than I can... Good luck!
__________________
I'm finally happily married!!!!!!
Supah Fly Civic Gurlies Member #1
Corona Lovers Club Member #3
R.I.P. Diana Ham (better known as FlyPoofGone) She is sincerely missed. Fallen Civic Gurlie #14 Angel......
AdmireMyGr8ness is offline   Reply With Quote
Old 07-03-2005   #3 (permalink)
markciotti
New Member
Thanks for your response. My current radio is the original factory radio, works fine except the volume control doesn't always work right. Also the antenna is slightly bent and I'm not sure it's plugged in the radio as my station reception is limited. Everything in the car is factory parts as far as I know. When I bought it 2 years ago it only had 49,000 miles on it and all repairs I've had done was with new Honda parts. The replacement factory radio I bought for $5 (seller claimed it worked when he pulled it and many other parts out of a 96 civic ex 4 years ago, but it's sat in his garage since then). I was hoping to test it without pulling the original factory radio out of my dash first (my mechanical knowlege consists of filling up the gas tank and having the oil changed, LOL). I'm not even really sure of how to pull the old radio out of the dash.
Thanks for any help you can provide. Have a great 4th!
Old 07-03-2005   #4 (permalink)
MegaHurtz
MegaHurtz's Avatar
MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of MegaHurtz has much to be proud of
Send a message via AIM to MegaHurtz Send a message via MSN to MegaHurtz
The best way to test it would be to remove the radio that is in there right now, and plug in the new one that you want to test. It won't be that hard to remove the current radio and plug the new one in quickly, it would be a lot easier than trying to test it otherwise.
You will not need any special cables or connectors. If you are going from one factory radio to another, it will be entirely plug and play.
You should not need any special tools either, other than maybe a socket set and a couple of screw drivers.
You shouldn't have too much trouble swapping out the radios, the hardest part will be figuring out how to take your car apart so you can get the current radio out, and I am sure you can find a guide online (P.S. here is the guide: http://www.installdr.com/InstallDocs...PDF/466013.pdf). All you will need is the phillips screwdriver and 2 sockets, the other tools are only for an aftermarket radio installation. Just follow the instructions and you should be fine.
__________________
Proud member of West Coast Extreme SPL
Come to the Mid-A meet 2007! This could be you!
MegaHurtz is offline   Reply With Quote
Old 07-03-2005   #5 (permalink)
AdmireMyGr8ness
Retired SuperMod
Thanks Ryan, I knew you could help...
__________________
Old 07-03-2005   #6 (permalink)
markciotti
New Member
Thanks for all the information and link to the installation instructions Ryan.
Thanks also to Admire my Gr8ness for your help and referring Ryan's help. I hope to try this next weekend, still carrying my currently useless remote with me. <G>.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Ipod to Factory Radio Without Adapter LastDojo Honda Civic DIYs and Civic Tech Chat 9 07-19-2005 09:36 AM
New Car LakelandCivic I.C.E. & Electrical 7 11-01-2004 10:47 AM
amp help Farage I.C.E. & Electrical 4 10-23-2004 10:36 AM
installing new equipment civicgurl1226 I.C.E. & Electrical 20 09-17-2004 12:23 PM
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
My new 4th gen hatch
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
Shifting problem, won't go into gear
Power Window issues on my 96 EX
96-00 ex rear disc conversion?
Turbo Kit for D16Y8 (44K miles)
Tire Size
Lets Get some Pics of Older Civics in Here
Site Supporters
aluminum radiator
Honda car spoilers
