Sponsored by:
Sponsored by: DashLynx
D17A (JDM) Oil Pan Size?
Old 03-17-2017
obtrectation's Avatar
obtrectation is an unknown quantity at this point
Hey folks, I just bought a 2005 Honda Civic EX Special Edition with a D17A (JDM) VTEC engine. The oil pan has a huge dent and I suspect it's causing the VVT code (sputtering past 4k RPM). Problem is, I can't find any documentation stating the correct oil pan size for this particular engine. Best I can tell it's steel, not aluminum. I appreciate any answers forthcoming. I need to place the order ASAP! Calls to local auto supply stores have been fruitless, apparently they don't know what a JDM engine is. A link to the appropriate oil pan and matching oil pan gasket would be super helpful too! Thanks again folks!
obtrectation is offline
Old 03-17-2017
Re: D17A (JDM) Oil Pan Size?
A cast aluminum pan would not be likely to dent, it would crack and break.
So your pan is probably steel. Stick a magnet to it to make sure.
We don't reference size when looking up parts for a stock unit.
You're ordering parts all wrong.
Tell the parts store you have a 2005 Civic LX, (the engine in a stock LX is non-vtec and has a steel pan), sedan or coupe whichever you have, and whichever trans you have, etc..
Order an oil pan for it, along with a new pan gasket.
You may want some exhaust gaskets and maybe some hardware since the pipe has to come out from under the engine to get the pan off.
If the pan not in horrible shape, you might be able to pound out the dent and reinstall it with a fresh gasket?
OTOH If it's really bad you may discover the oil pump pickup tube damaged and needs replaced too.
Honda dealer catalog online, many dealers are online selling genuine parts at wholesale prices:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=2005&catcgry3=2DR+LX&catcgry4=KA4AT&catcgry5=CYL INDER+BLOCK+-+OIL+PAN
ezone is offline
