Keyless entry
Rep Power: 0 Keyless entry
I have a 2002 civic ex, without buying a key fob and trying to program it... anyone know how I can check to see if my car has it? I bought it and it only came with a key. Thanks
Rep Power: 0 Re: Keyless entry
Yes so mine does have the box. So my next question is, can I order any key fob off amazon? I noticed in the descriptions of the listings they state "replaces so and so models" how do I know which ones for my car? Thanks!
Re: Keyless entry
I think there were several OE fobs that look almost identical but are not the same internally.
IIRC the factory equipped units took a different fob part# than the dealer installed accessory type fob but they looked identical on the outside.
Re: Keyless entry
I'd just look up the correct parts in a Honda parts catalog. Might not be the cheapest choice, but at least it's correct....no guessing.
For an 02 EX I came up with Honda part# 72147-S5A-A01
http://www.hondaautomotiveparts.com/
Here for the food
Noted! I'll check. The car was a gift and all I got was the key. Lolol.
Programming it shouldn't be too difficult right? I programmed a couple of fobs for my 09 Accord EX for unlock/lock a year or two.
Yes programming is easy. And can be found online. The difficult part for me was trying to program two remotes at the same time. For some reason one kept cancelling out the other one. I don't know how I did it but I did end up getting both to work.
Re: Keyless entry
Ive installed oem receiver unit onto my 01 lx and despite hookinmg it all up exactly as prescribed by countless info from forums here ive yet to be able to program the remote.
Re: Keyless entry
Guess#1 Miswired or mispowered
Guess#2 fob doesn't match control unit
Guess#3 method incorrect
Re: Keyless entry
M ive got a circuit tester the yellow is hot while key is on the other is hot constantly and the blue orange one is spliced into the blue orange wire from the ten pin connector behind cigarette plug.
The fob matches the module for sure.
Re: Keyless entry
Did you mis-spell TWO?
If you found some random 10 pin connector in the general area, with the same colors on some wire....that's not right.
You must find the correct TWO pin connector that contains the MICU data communication line (it's the only wire in the connector).
