F/IC question
Rep Power: 0 F/IC question
probably dumb af but will this work for running my turbo on a d17a1 ? around 6 psi and rsx s injectors.
https://www.amazon.com/AEM-30-1910-C.../dp/B001DX58KA .
that should be all i need correct? or will i need some other piggyback for other fine tunning ?
Received 1,148 Likes
Rep Power: 485 Re: F/IC question
dezod.com ran 8psi on a 7thgen using an fi/c with nice results. Just make sure you get a good tune.
[shameless plug]I have one that's been sitting around for a long while. Never installed, only test fitted. Was gonna use it on my turbo setup, but I've since taken the turbo off and haven't had the funds to go boost again. I also have a PnP harness for it..[/shameless plug]
