Sponsored by:
Sponsored by: DashLynx
airbag impact sensor
Old 12-31-2016
rrhas's Avatar
rrhas is an unknown quantity at this point
2005 civic sedan front passenger side impact sensor wires pulled out of plug
can i just reinstall and seal them which way do they go in black on top/green bottom or vise versa it looked like black on top but not sure have photo attached
rrhas is offline
Old 12-31-2016
Re: airbag impact sensor
Those wires are broken off of the metal terminals inside the connector shell.
Shoving the broken wires into the holes isn't good enough.
I'd strongly urge you to buy the wiring harness if you expect the SRS to work as designed in the next crash.
Harness replacement may not be the cheap option nor the only possible option for repair, but it's the only Honda approved option.
ezone is offline
Old 01-01-2017
CraigW's Avatar
Some of the front stuff related to harness is made available for crash repairs.
Or try.....www car-part dot com
CraigW is offline
