2005 front end swap
Rep Power: 0 2005 front end swap
I have 2005 civic sedan my daughter just smashed front end
had it checked out just panel damage hood, fenders, bumper, passenger door,
lights all to be changed. Can get a 2002 civic sedan for parts will they fit my 2005
Prelude Owner
Re: 2005 front end swap
Yes i believe it will if you replace all the components that you mentioned (not the door) plus the headlights. 01-02 are the same and 03-05 are the same.
Search 7th gen civic front end conversion, there is a thread around here someone that has the info.
Rep Power: 0 Re: 2005 front end swap
you mean the 2002 door won't fit the 2005
Prelude Owner
I believe the doors are the same so that shouldn't matter.
Post #4 in this thread:
https://www.civicforums.com/forums/1...like-05-a.html
If you can find an 03-05 that would be best.
just read with front swap 2005 to a 2002 headlights are different 2005 has 2 bulbs 1 for hi beam 1 for low beam 2002 only has 1 bulb hi/low combined
i guess the 2005 harness must be changed for the 2002 bulb any wire diagrams
Received 1,148 Likes
Rep Power: 485 Re: 2005 front end swap
Back to OP, if i remember correctly, upper radiator support needs to be swapped or modified.
Also, as far as the headlight goes, you can make a conversion harness yourself, if you're electrically savvy. Grab a pair 9005 and 9006 female harnesses (I think they sell them at autozone) and a pair of H4 male harnesses (likely have to source online). On the 01-03 civics, the H4 bulb is ground switching (i.e. switches the ground wire source when flashing your high beam). The pic I just made below is as if you were looking at the pin side of the H4 male harness
If you wanted to convert it yourself, it's just a matter of soldering the right wires on the pigtails. If you buy pigtails, they should have enough of a wire lead that you don't need to add extra wire. Heat shrink the solder joints, wire loom for aesthetics, and dielectric grease to stave off corrosion on the (h4) pins, and you should be good. I drew up a quick and dirty (9005/9006 to H4 diagram).
One set of these and two sets of these should be all you need
You're correct. I drew the pins on the wrong side. you need a female H4 pigtail. The wiring still works out the same on my crude little quick and dirty diagram.
I have swapped the front end of my 2003 Honda Civic EX sedan with a 1.7 D17A2 5 speed with a 2004 model of the same color and model. I had to change the core support also since the car was involved in a collision. I couldn't find a 2003 model of the same color and wanted to avoid painting. So now I find that the connectors to the wiring harness are different. I got the turn signals wired up by splicing the 2004 connectors on. But the main headlight connector is a three pin and the 2004 headlight only has a two wire connector. So how do I splice the three wires to the two wire connector? Also for the parking light which has two wires does it matter which wire I connect from the 2003 harness to the 2004 connectors. I had to take some connectors off a 2004 Civic since the opening in the new lights are different diameters with different locking features where they plug into the headlight assembly. Thanks for any help that you can provide.
