Sponsored by:
Sponsored by: DashLynx
Valve cover gasket/oil splashes everywhere
Old 12-05-2016
Yager777's Avatar
Yager777 is an unknown quantity at this point
Hi, could someone help me out... I have a 03 Civic LX 1.7 I changed the valve cover gasket for the second time and when I start driving oil splashes everywhere and starts smoking like crazy. I don't know what else to do.
Yager777 is offline
Old 12-06-2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: Valve cover gasket/oil splashes everywhere
Give it a good cleaning so there is no or almost no old oil. Then have someone turn the car on while you check to see if you can spot the oil leak. Or take it on a very short drive and see where the leak is coming from.
Check the plug on the left side of the head where the distributor would be if it had one, this plug/seal deteriorates and could cause a bad leak.
GusBuz is offline
Old 12-07-2016
Yager777's Avatar
Okay, thank you
Yager777 is offline
Old 12-19-2016
bhcjr's Avatar
bhcjr is an unknown quantity at this point
I have the same issue in my 01 Civic LX. The main area of the oil present is on the driver side .
bhcjr is offline
Old 12-20-2016
GusBuz's Avatar
If you still cant find the leak. Try cleaning off all the leaked oil, and use some leak detection dye in the engine oil. Drive it around for a bit and then go back and check with a black light or uv light that is used with the dye. You should be able to spot the oil leak easily.
but the other method of cleaning and checking is good for most all leaks. You will be able to find the leak after you clean off the old oil, this way you see the fresh oil dripping out of someplace
GusBuz is offline
