Sponsored by:
Sponsored by: DashLynx
no pressure in clutch pedal
Old 06-27-2016
bryan1995's Avatar
bryan1995 is an unknown quantity at this point
so i started swapping out my girls 03 civic (em2) with the jdm d17a got it all running working fine but i came across a problem that happened before i swapped the motor and their is no pressure at all going to the clutch pedal. i have replaced the clutch master cylinder twice and the slave cylinder as well with the front line that goes to the slave (keep in mind that the parts are from autozone) i bled from the slave and i bench bled the master and still no pressure build up on the pedal??? ive going at this for about 2-3 weeks now and still cant resolve the problem. ive been doing some research and read that you have to use the oem master cylinder from honda??? any help would be appreciated im going crazy trying to figure out what the problem is
bryan1995 is offline
Old 06-28-2016
mikey1's Avatar
Re: no pressure in clutch pedal
you have air in the system,
describe the method you are using to bleed the system
mikey1 is offline
Xavier11
01-22-2016 03:50 PM
M00n3at3r
General 7th Gen
20
11-03-2015 09:18 PM
Jdm_brian
10-22-2015 12:04 AM
Deputy702
Lighting
10-20-2015 12:43 AM
meels808
11-20-2001 09:37 AM
Quick Reply: no pressure in clutch pedal
