Engine removal
Rep Power: 0 Engine removal
I need help on pulling my motor every thing I sees says drop it from under neath can I pull just the motor from the top ? Do I have to pull the trans and motor together
Rep Power: 0 Re: Engine removal
Just go slow and make sure you clear the AC lines and everything as it lifts out.
Re: Engine removal
Having pulled the motor in my 03 many times, I suggest hooking your lift onto the motor, dropping the trans through the bottom, then hoisting the motor out the top. Takes just a little longer, but it makes it much safer for you and the parts that like to get hung up, much more space to work with.
Received 1,146 Likes
Rep Power: 485 Re: Engine removal
I've taken engine/tranny from my 02 as an assembly out from the top with no issues. Just my 2 cents.
when dropping it back in, go slowly, make sure you don't pinch anything. That's what I did, and it went it with no issue.
rtnav
05-31-2016 12:49 PM
j.stoltz
05-13-2016 08:15 PM
