Is it worth it
Rep Power: 0 Is it worth it
I have two options the car has 246000 miles, I can get a refurbished head with a warranty for a year or get a used motor that has a 3 month warranty with 108,000 miles do you think if I put a new head on my motor it will last ? Or should I get the motor it's a 100 mile drive and he wants 800 for it
Rep Power: 131 Re: Is it worth it
What's the current condition of the existing motor? Are you having problems, burning oil, or is it running fine?
With mileage that high I would imagine the piston rings are starting to stick. Replacing the head and still having stuck piston rings, you'll still have compression loss and most likely burning oil. If you take the head off then you can theoretically replace the piston rings at the same time while taking the bottom half of the engine apart and taking the pistons out. So just replacing the head and head gasket might not be enough if you're looking to rebuild your existing engine.
With a slightly used engine you could possibly get another 150-200K out of it without having to do a lot of internal work. But that depends on the condition of the used engine of course. You don't know the service history, oil change interval, etc. If possible I'd try to get some compression numbers for both wet and dry tests. That would give you some idea of the internals of the engine. But if it's for sale then it's probably out of the car. At 108K it's recommended to replace the timing belt, was that done by any chance?
Would you be rebuilding/installing the engine or having a shop do it?
Rep Power: 0 Re: Is it worth it
The guy doesn't know of the timing belt has been changed or not the motor in my car was leaking oil but not burning oil I already have the head off so I could put rings in it I have rebuild a few motors and I can't imagine it being to change rings
Re: Is it worth it
If you already have it apart and you know what you're doing, I think it would be pretty easy to just put a set of rings in it and go another 200k+.....if the rest of the car holds up
(In the rust belt you gotta mile them out before they rot away to nothing)
(In the rust belt you gotta mile them out before they rot away to nothing)[/QUOTE]
The car come from Virgina a year ago so it's seen one winter in PA it's in pretty good shape besides some dings here and there
I found a motor 131,000 miles for 550 I figured that would be the best bet VA replacing the head and everything my question is when I pull the motor do I need to pull the motor and trans or can I separate it first and pull the motor I already have it down to pretty much the block any advice or a link to another form would be great thanks
Re: Is it worth it
I guess it depends on the situation and your equipment.
With automatic trans it needs about an inch of room to clear the flexplate and stuff in the bellhousing area....some people might remove the crank pulley and take the engine out the top. (don't screw up that big AC pipe that runs over the engine)
A manual trans requires a whole lot more room to get the engine and trans separated, one might pull the trans away from the block then yank the engine out the top...
Or I might drop the entire drivetrain out the bottom as a unit then separate the engine and trans on my hydraulic table.
Re: Is it worth it
AFAIK people have done that swap and it runs fine........ then later on you could get a standalone controller to run the VTEC or connect it to a toggle switch for full manual control LOL
What's AFAIK? and would it matter on the years it's a 03 motor and my car is an 04? Would that matter
I know the 04,05 have different O2 sensors/system and the ECM is different between the 03 and 04 but I'm not sure if that makes a difference when swapping the motor. I wouldn't think it would, but if you're going from a 04 non v-tec to an 03 v-tech it might be an issue.
Re: Is it worth it
LOL click this link: http://bfy.tw/4Z7i
You're really only swapping to get a good block and head, you can swap all the manifolds and EGR and other stuff if they don't match exactly.
And what Hawkinz says here too:
Use the O2 sensors and exhaust manifold/cat from your original engine.
Compression in the VTEC engine is a little higher too.
Aluminum oil pan on the VTEC engine may or may not work right, I think the dude posting videos has one where he figured that part out and has some info about it
Correct AFAIK.
Well from everything I read it should matter if it's a vtec as long as I leave it unhooked it will act like it was never there
Re: Is it worth it
Oh ok LOL. Yeah some have it, some don't.
I don't bother to remember which versions do or don't, I only pay attention when there are problems.
It came out, about had to stand it on end. dropping the trans below the sub frame to get it out. Had an inch clearance total.
When it came time to drop the new motor in, he's nowhere to be found! Had to do it myself. And Heck! I don't know anything except what I see on You Tube!
But I did it. Took a while and a half! After it's in I'm hooking up this-n-that and wonder "Where's the power steering reservoir bracket?" He'd taken that off and didn't tell me. Had to take the power steering pump back off to get that 10mm bolt in.
I wished I'd taken it out the bottom!
So, you're supposed to get it aligned after removing the sub frame? I just spray the head of the bolt and surrounding sub frame with white paint and put it back exactly where it was.
I've done them both ways, and for me in the future if it's automatic it's going out and back in from the bottom! Engines with manual trans come out of the top OK.
Re: Is it worth it
If the steering wheel ends up crooked while driving straight, then I'd say align it.
got the motor in changed timing belt water pump and everything when it was out got the oil in it and the coolant and started right up now to remember how all the belt driven accs go on also im having trouble with my air filter box fitting on this motor does anyone know if its any different from 03 to 04 or different from the non vetec to a vetec motor ? i dont have much to go hoping to finish it tonight after work
Re: Is it worth it
The bolts and holes on the passengers side should be self explanatory.
over45
03-21-2016 01:05 PM
MamaBear2015
Electronics
03-15-2016 06:19 PM
