2004 acura EL priemum starts fine sometimes then doesn't start sometimes
Old 05-23-2016
tortoise's Avatar
tortoise is an unknown quantity at this point
Hello having some starting issues with my 2004 acura El premium Canadian model. Fancy civic
Sometime it starts right up no problems then sometimes it wont start it just cranks over but won't fire up it will take a few key turns to get it too start when it dose that then it runs rough for 2 sec then it's fine like nothing happened or was wrong.
It wouldn't start 4 times after i shut the car off today when i was out took about 3 or 5 key turn to make the car start up after but then sometimes it would just start up like their was no starting problem.
Then i was at the gas station filling up took about 10 mins to getting the car to start after i put gas into it would just crank over it would not firing up then bam it started went home shut the car off tryed to restart it it just started up no problem even know 5 mins ago it wouldn't start at the gas station?
Iv be doing some research and found that few acuras that are doing this have bad cranked soders in the relay under stearing wheel that control the fuel pump.
Could this relay be causing my starting problem to not start sometime then the car starts just fine sometimes & is the relay in the same spot as the acura cl under the stearing wheel or is it in a different spot cause its a 2004 acura el premium Canadian model.
i cant seem to find the relay under the dash!
would like to hear what what people think of this problem
tortoise is offline
Old 05-23-2016
Prelude Owner
GolNat's Avatar
Re: 2004 acura EL priemum starts fine sometimes then doesn't start sometimes
I had a similiar issue with a different car that was fuel pump related. Fuel pump wouldn't hold its prime. I would have to cycle the key a few times to get it started (only after the car had been sitting).
Do you have fuel pressure at the rail?
GolNat is offline
Old 05-23-2016
Doesn't have one.
On a Civic, there are several relays behind the glovebox, tip it out like you were going to replace the cabin filters and you'll see them.
You'll probably need a real good wiring diagram to identify what each of the several relays are for (I.D. relays by their wire colors).
Main relay 1,
Main relay 2
A/F sensor heater relay
B/U light relay
If you suspect a fuel pressure problem, it would be wise to use a fuel pressure gauge to prove it......... or a test light to prove the pump isn't getting powered up. Test, don't guess.
Prove there's a problem, before buying expensive parts it may not need at all, and low quality parts from parts store chains open on Sunday that are less reliable than the original parts with a ton of miles on them LOL
ezone is offline
Old 05-23-2016
tortoise's Avatar
ill have to check pressure. But wouldn't it do everytime not intermittent starting. Today it has been good started every time i went out today. It is alot cooler out today maybe that has somthing to do with it.
also throwing a code for Po118 engine coolant temperature circuit. I see it go up and down befor at the redlight or in the drive way. But dont think that would cause it unless its say its too hot to start or somthing.
tortoise is offline
Old 05-23-2016
tortoise's Avatar
Originally Posted by ezone
Doesn't have one.
There are several relays behind the glovebox, tip it out like you were going to replace the cabin filters and you'll see them.
Main relay 1,
Main relay 2
B/U light relay
ok ill check the fuel pressure. I do hear the fuel pump turning on and off befor i turn the key. The car didnt have a no start problem today started every time today. It is alot cooler today though
tortoise is offline
Old 05-23-2016
HOLD IT RIGHT THERE
Damn, tell us these things in the first post. This is your problem. ALL of the problem. Fix this.
ezone is offline
Old 05-23-2016
tortoise's Avatar
HOLD IT RIGHT THERE
I just had my buddie run the coder about 25 mins ago so didnt know. i only had the car for 2 weeks. Ill have to get a replacement is this the part right by the egr valve
tortoise is offline
Old 05-23-2016
Yeah that sensor not only tells the computer (PCM) how hot it is (or lies about it) it is also what you read on the temp gauge on the dash (it reads data from the PCM, not directly from the sensor).
The PCM needs that sensor to be dead nuts accurate in order to get the fuel injected quantity correct. Any inaccuracy can lead to your symptoms.
ezone is offline
Old 05-23-2016
tortoise's Avatar
So both codes buddie forgot one the one is p0118 and p0128 2x he said. I just got this information 2 mins ago
tortoise is offline
Old 05-23-2016
Fix the P0118 problem first.
Then erase codes and see what happens.
Reason: P0128 can be caused by the P0118.
ezone is offline
Old 05-23-2016
Which engine does it have?
ezone is offline
Old 05-23-2016
tortoise's Avatar
Its the 1.7 singl cam none vtec 126 hp
tortoise is offline
Old 05-23-2016
Then the sensor is right behind the top radiator hose fitting on the engine. You can see the hex of the sensor just above my finger here in this pic
ezone is offline
Old 05-23-2016
tortoise's Avatar
ok right where i thought heres my picture what is this part name or the part number if you know. Ill get a replacement for it and report back if this fixes this starting problem.
tortoise is offline
Old 05-23-2016
Usually ECT sensor, and be able to point it out in a parts catalog yourself if they can't find it.
I only have a catalog for US Hondas, not Canadian Acura.
Check around for online dealer parts catalogs or visit your local parts stores?
ezone is offline
Old 05-23-2016
tortoise's Avatar
Ok sweet thanks alot for the help iv highly appreciated it! Ill report back when i get a replacement tomrrow and see how it gose and get the codes cleared.
thanks aging!
tortoise is offline
Old 05-23-2016
https://www.acuraoemparts.com/
Does not list an Acura EL??
EDIT: Durr, that's not a Canadian site LOL
ezone is offline
Old 05-24-2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
The part # should be the same as the Civic.
So cold starts had no problem starting and when at operating temp, that's when you had hard turning-over?
NDNV is offline
Old 05-24-2016
Civic version, Canadian
Part #17
Linkyclick
http://torontohondaparts.com/PartsLi...ine&illid=5757
ezone is offline
Old 05-24-2016
tortoise's Avatar
Part #17
Linkyclick
Ok so i got a replacement one installed it. Just gotta wait too see if it still gonna do it
tortoise is offline
Old 05-24-2016
tortoise's Avatar
Yeah every time i left the house it would be fine but if i stop somewhere and tryed to re start it would do it but not every single time sometimes here and their it would. Been doing it alot more since its getting hot here in Canada Ontario. I only had the car for 2 weeks
tortoise is offline
Old 06-07-2016
tortoise's Avatar
Ok so it been 2 weeks since i replaced the ect sensor, the car has started up every time hot or cold since i replace the sensor.
thanks for the help!
problem solved!
tortoise is offline
Old 06-08-2016
NDNV's Avatar
Thanks for posting a follow-up solution. I hate open-ended posts.
NDNV is offline
rford65
11-22-2015 11:22 AM
E Sully
11-12-2015 06:30 PM
BBrosario
11-05-2015 06:28 PM
TaiChi
Canada West
11-08-2001 01:21 AM
Quick Reply: 2004 acura EL priemum starts fine sometimes then doesn't start sometimes
