Sponsored by:
Sponsored by: DashLynx
wheel fitment has my head spinning!!!
Old 05-12-2016
dweesb's Avatar
dweesb is an unknown quantity at this point
Hello all,
I'm looking to put wheels on an 01EX. I'm not interested in lowering the car... yet. Mainly because I want to put the stock wheels back on for the winter season, and lack of funds. Baby steps.
So the question I have is how big can I go (diameter and width) without running into rubbing problems? I like the look of the stock set-ups on the WRX's. So that's the look I'm striving for, filling up the wheel well.
The tire fitment guide post has great info, but just not answering the questions I have.
Thanks in advance for any help.
dweesb is offline
Old 05-12-2016
Prelude Owner
GolNat's Avatar
Re: wheel fitment has my head spinning!!!
If you want to fill up the wheel well then you need to lower the car. Going to a larger diameter wheel means going to a smaller sidewall tire so your overall wheel diameter does not change (this throws off your speedo).
Really just lowering the car on stock wheels will fill the wheel well and look great.
Example:
GolNat is offline
Old 05-13-2016
dweesb's Avatar
Example:
Thanks for the tip.
How about width? I'm looking at a used set that I'm having a hard time passing on, but they are 215/45zr/17. The width has me waffling on the purchase.
dweesb is offline
Old 05-17-2016
SammySC's Avatar
SammySC has a spectacular aura aboutSammySC has a spectacular aura about
Example:
Very nice drop! I have the same exact car, color and everything!
SammySC is offline
Old 05-17-2016
SammySC's Avatar
17" wheels lowered on Tein street advance coil overs. No rubbing at all. I don't remember the tire dimensions but can post it later if it helps.
SammySC is offline
Old 05-17-2016
XXWoodmanXX's Avatar
XXWoodmanXX is an unknown quantity at this point
To go along with that, it seems the highest offset I've seen fit the "stock" fender/wheel wells (without having to roll them, and @ 0-degrees front/rear camber) is 40mm. Any higher and I think you might rub.
FYI.
XXWoodmanXX is offline
Old 05-17-2016
dweesb's Avatar
FYI.
Excellent. Thanks everyone.
dweesb is offline
nielboy
01-08-2024 05:14 PM
91LXdriver
Wheels and Tires
05-10-2016 06:46 PM
Chameleon117
05-03-2016 07:55 AM
Gabegv
04-22-2016 01:38 PM
Omarem2
04-19-2016 01:12 PM
Quick Reply: wheel fitment has my head spinning!!!
