Sponsored by:
Sponsored by: DashLynx
civic 2001random overheating
Old 05-01-2016
contevo's Avatar
contevo is an unknown quantity at this point
hello, start overheating 2 days ago and happen when i was sitting at taco bell parking idling and add some coolant and shut it off for a bit and drove off fine, this happen two days ago and today happen again. takes me about 20 mins get to work and i didnt notice any overheating till got my job parking lot and sat there for few mins notice niddle all the way to H. i open hood and fan was on and notice coolant reservoir overfilled and kill the engine for a min or two and turn back on coolant reservoir went down and niddle when down slowly. what can it be ?
contevo is offline
Old 05-01-2016
Super Moderator
Poopies's Avatar
Re: civic 2001random overheating
Head gasket most likely.
Poopies is offline
Old 05-01-2016
coolant reservoir went down and niddle (needle?) when down slowly
Reservoir going back down doesn't scream head gasket yet IMO.
After the engine is cooled off, open the radiator cap and see if it is completely full of liquid all the way to the top.
If the radiator is completely full, it might not be head gasket.....but if it's been hot it can't be ruled out as collateral damage.
When you opened the hood on the HOT engine and saw the fan was running, was the AC on or not? (AC causes fans to operate too, so I'm wondering if the high coolant temp is what made the fans run when you saw it...this is an important piece of info for diagnosis)
I might look for a blockage of air flow through the radiator and condensor fins (dirt/sand/bugs/leaves/trash/damaged fins), and check for internal deposits in the radiator core (calcium/lime), either would cause a problem with heat transferring from the hot liquid in the radiator to the air being pulled by the fan blades.
You could try using a garden hose spray nozzle to wash out the outside radiator fins, go from the engine compartment side and wash the stuff out toward the front of the car.
ezone is offline
Ethan9263
04-28-2016 11:21 PM
emSLOW
04-24-2016 11:44 AM
TS2008
04-14-2016 06:08 PM
reckless346
03-03-2016 10:45 PM
DreamingBlind
02-26-2016 10:30 PM
Quick Reply: civic 2001random overheating
