Clutch not disengaging
#31
Rep Power: 0 Re: Clutch not disengaging
On a side note, I put the new master on found out there's a leak.
After pushing the clutch fork against the slave cylinder, I heard what seemed to be liquid shooting out somewhere along the line. Looked at the master cylinder and fluid was shooting out of the RETAINING CLIP. So I hammered that bitch of a clip in as far as it would go, and it still shoots liquid.
I'm gonna put some threadlocker on it, that'll keep it sealed!
#33
Sounds like the rubber seal under that fitting is damaged. It's easy to do, i usually order an extra whenever I have to replace a master.
#35
Would it make a difference if I just pressed on the master cylinder pushrod by hand? everything is hooked up. This way I can avoid having to mount it back to the firewall till I know it's bleeding.
#36
That would be about the same as bench bleeding.
Did you bench bleed it already?
#37
#42
The thing was designed so you do not disassemble the fitting from the line,
You were supposed to pull the retaining clip out to let the fitting lift up out of the master cylinder, leaving the line and fitting together in the car.
I've never taken the fitting off of the line.
IDK what to do next.
I know I've trashed the rubber seal under the fitting while attempting to reassemble the thing in the car....about every other job I ruin at least one seal LOL. I have at least one spare in my toolbox.
#43
Guess I'll try some JB water weld to seal it up, seems like the most logical thing to do unless I can buy a fitting and retaining clip by itself.
#44
#45
#46
#47
It's a flat rubber ring, right? It would go into the hole of the master cylinder first, so that's #3.
Your fitting goes into the hole next, so it sits on top of that ring.
The hairpin clip goes into the slot #2 (where all the chew marks are)
Honda also shows a special (somewhat expensive) silicone grease in this bulletin used to lube the ring and for the squeak issue that can come from the swivel fitting. See this PDF
#48
I'm gonna seal that up properly and will be back with an update!
#49
Well I got the new seal onto the plastic fitting, did a bench bleed and everything worked fine. Once I got the master cylinder mounted to the firewall and the clutch line fit, I go to press on the clutch fork to release any bubbles in the line, and fluid shoots out of where the retaining clip is.. I'm wondering how this is possible with the new seal, is the clutch line clogged somewhere?
#50
Pressure leak
Seems like fluid would have to get past the seal in order to reach the hairpin clip section of the fitting-- through damaged seal or maybe scratch/gouge in the metal, or maybe fitting isn't held all the way down in its hole,
Maybe somehow the fitting got cracked or the hairpin isn't original (replaced with coat hanger wire?)
IDK. I can't see it from here, all I can do is guess.
#51
Pressure leak
I'll check back with an update..
#52
Pressure leak
#53
#54
I checked that seal in the master cylinder when I took the fitting out, and what do you know it wasn't set all the way down in the hole! So I attached it to the fitting instead then reassembled everything. After that there wasn't any fluid coming out where the retaining clip was, so I bled the system with a mityvac knock off and the pedal didn't stick to the floor, for the first time in probably 2 weeks.
Although the pedal is softer than it was before all this, I'm just glad it comes back up without having to pull it. It also has a lot of play, about an inch or two before there's significant pressure. I'm guessing that's because of air in the system or the pedal needs to be adjusted?
#55
Better look up how to adjust the pedal before you do it. There MUST be some free play (see FSM for spec).....If there is no pedal pushrod free play, the system can hold the clutch partially applied which leads to slippage and short life.
#56
Ezone, I don't think I've said it, and can't say it enough, but thank you for all the help and advice you've given me through this process of my own screw up. What started with a squeaky clutch ended up with this, but I'm just glad to be on the road again!
I've learned a lot these past couple weeks, and couldn't have done it without your patience and help. You deserve an extra bonus from Honda for seriously knowing your ****, all the way down to a measly little seal. Lol. It's nice to know there are people on here willing to help this much, so thank you again.
#57
Good to hear it man!
I work for a Honda dealer, not Honda. The only bonus I might get is lube on payday LOL
#59
From the FAQ:
How do I find my way around?
When you click on a forum's name, you are taken to the list of threads it contains. A thread is a conversation between members or guests. Each thread starts out as a single post and grows as more individual posts are added by different users. Threads can be rated (?) to show how useful or popular they are and may contain polls (?).
To start a new thread simply click on the 'new thread' button
#60
Rep Power: 125 Re: Clutch not disengaging
I've been a forum member for 2 years. My wife wants me to replace my little 7th gen, but no way. It runs great, its efficient and thanks to you and others on this forum, I've been able to do everything on my own.
Although I have 2 teenage boys, I don't have a car payment, my insurance and gas are cheap and I have been able to teach my son's to work on cars (they don't realize it yet, they're just helping Dad...)
I have been able to afford to put my money into other things for the family instead of car payments or repair bills...
Thanks for making a difference in my quality of life!
