Learning/Doing Car Maintenance
Rep Power: 0 Learning/Doing Car Maintenance
Currently own a 2003 Honda Civic LX which as of this posting has 226,000 miles. I got it from a family member for free when it had 197,000.
When I first got it I took it to a shop to get it serviced, to check/change fluids, to inspect and what not, but since then I've been trying to learn and do the maintenance myself.
Things I've been able to do so far:
- Oil and oil filter change.
- Cabin air filter.
- Engine air filter/cleaner.
- Brake pads. (One pad was basically gone so need to change my front rotors since it was gouged and had groves, but doesn't look hard.)
I've also just recently gotten new wheels and tires (off TireRack with tires already mounted and balanced, and put them on myself) since the ones I've had were getting cracked, bald, and just got punctured. Then took it to a shop to get aligned.
And so now I was asking to see what's are next things I should/can try to do myself in terms of getting more technical or increasing difficulty.
Also, trying to maintain this car for as long as possible so anything else I should be doing in terms of maintenance that I should be aware of is good too. And since the car was free and probably doesn't have much value in selling I plan on keeping it as a learning tool and hopefully lead on to learning to do car changes/modifications like ones I've seen on here like steel braid brake lines or a short/cold air intake or something along those lines.
- Cabin air filter.
Re: Learning/Doing Car Maintenance
your next priority should be changing your timing belt if you are not sure when it was changed last, although that job might be too complex for you from the sounds of your post (no offense)
Received 1,440 Likes
Rep Power: 338 Re: Learning/Doing Car Maintenance
I were you, there are some places that sells:
1) Owners manual - i got mine from a place in the internet
I got my service manual and owner manual from here:
http://www.helminc.com/helm/homepage...q=helms+manual
service manual is steep price
You can also find the Haynes or Chilton manuals in any of the autozone/advance auto parts stores, etc.
having friends that know cars also grat help for a 6-pack and afternoon spent
First, congrats on the nice pick up. A free Civic is never a bad thing :-).
Second, congrats on wanting to learn about your car. I really think you can fix a bunch of things on your Civic. It just takes some patience and a willingness to fail and learn. Do you happen to have a repair history on it? It doesn't sound like it, but I was hoping :-).
I really enjoy working on my car. It can be fun, challenging, and absolutely frustrating at times. But, I love it.
Oddly enough, I never change my own oil. I have found that most times, I can negotiate that as part of a service price or find coupons and it ends up being cheaper than buying the supplies myself.
As others have mentioned, you most likely need a timing belt. I do not think you should do that yourself. But, when you do take it in for service, don't forget to negotiate your "free" oil change :-). In addition, the shop/dealer is usually pretty good at giving you a laundry list of everything else that "needs" to be fixed. That would be a pretty good place to start before starting on other types of "mods."
I think a service manual is a fine idea, but I find that I never use mine anymore. I always go to the internet and videos for information.
If you do decide to change the rotors, be sure to invest in an impact screwdriver (cheap one for $8, nice one for ~ $25). Check out videos on changing rotors. It is straight forward, but you need the right tools.
How are the struts? If you need to change struts, I suggest the Gabriel Ready Mount struts. They are insanely easy to install and you do not need to worry about compressing the springs. (Don't forget to take it in for an alignment if you do this)
You may also want to check out the motor/engine mounts. If they have not been replaced, then they are probably busted or very close to it.
Does it leak any fluid?
Good luck!
Good luck!
If you are wondering how bad cheap oil can be do a Google search for "Dollar General oil lawsuit".
PJB, you are absolutely right. Perhaps I should have been a bit more clear and I should not have made some assumptions.
I do not take my car to "small" shops or those quick-change oil places. I have heard too many horror stories and I simply do not trust them. I go to my local Firestone where the manager is a long-time friend and to the Dealership. I know the Dealer is not a guarantee of good service, but I would hope that even their cheapest oil still meets at least the minimum specifications required by Honda.
So, I guess I do trust my service centers.
Thanks for the heads up.
- Cabin air filter.
- Cabin air filter.
First do 5 oil changes quick first oil change at 500 miles, second at 1000 miles third at 1500 miles fourth at 2000 miles and final fifth at 2500 what this quick oil changes will do is flush your engine and it will get clean from any gunk that is built up in your engine. Mechanically if you keep your Honda good you will never get wrong. And also congrats on your new FREE civic. What ever you wanna do one recommendation do one piece at a time so you are not out of budget. Hope this help
