Rpm problems please help
Rep Power: 0 Rpm problems please help
Hello All,
I added a video of the problem I'm having. Once it reaches 3000rpm in dives down to 2000 then it goes up with out a problem. The car is a 2001 Honda Civic ex coupe. No cel lights does anyone know what this might be. Thank in advance
Rep Power: 0 Re: Rpm problems please help
Ezone,
Thanks for replying, the video is of the reaction I get when driving my car. The RPm's starts off fine then when it reaches 3000rpm it drops back down to 2000 till I get the engine back up to 3000 rpm then it is fine. I also feel a surge or push when the RPm's drop. Any idea from what it might be.
Still not much to go on here.... Without knowing anything about what's going on in the video it looked a lot like the trans just made a gear shift.
Even though there is no check engine light on (does it work at all?) did you check for any codes?
Cold engine? Hot engine?
How's your weather there?
Every time you reach 3000 it does this? Only once each trip? Random?
How far is your foot pushing the gas pedal when this happens?
What if you floor it, does it still act up?
First start of the day? 30 seconds after startup? Hot restart? After being in the store for 5 minutes?
Driving? Stopped? In gear? Neutral? Moving? at what speeds?
Automatic or manual trans?
No codes from the engine odb
Weather is cold here in NYC, notice only on cold starts
Only the 1st time it reaching 3000 rpm then it goes back up normally
Pedal is not to the floor just normal street driving, when I on the highway just the 1st time it reaches 3000rpm it does this drop and surge feel in the engine.
Also the cars an automatic
jdh022764
18
11-03-2015 06:44 AM
tropicola
09-25-2015 07:02 PM
chiquita.banana
09-24-2015 09:42 AM
Bartkat
20
02-19-2002 01:29 PM
