Sponsored by:
Sponsored by: DashLynx
Clutch Wont Disengage
Old 11-22-2015
cloudguy's Avatar
cloudguy is an unknown quantity at this point
2004 Si, 108k miles
I replaced all the hydraulics (master and slave, blew out lines with brake cleaner) on the car probably 6 months or a year ago. Starting this weekend the clutch wont fully disengage when the car is in gear. It will still change gears and everything fine, but if I hit the gas hard in any gear the RPMs will spike and the car will just slowly speed up. The clutch burning smell is also pretty bad too as another obvious sign.
I bled the hydraulics again just in case there was any air in the system. Made no difference.
I am fairly sure it is the throw out bearing, but if the whole transmission has to be separated from the engine the clutch might as well be done too.
I would normally be brave enough to tackle this job myself, but it is getting colder and the days are much shorter now and we cant really be without two driveable cars for very long.
Anyone have an idea what it should cost to get a clutch and flywheel replaced? I live in northern VA, close to DC so the labor costs are higher than other places.
Any thoughts on what else it could be that would be an easier fix? Definitely not a fluid leak, the reservoir hasnt changed level since I replaced the hydraulics.
cloudguy is offline
Old 11-22-2015
Re: Clutch Wont Disengage
Needs a clutch job.
No shortcuts or bandaids there, it's slipping under load.
No idea on price here, I don't do numbers and price varies widely.
Do pick someone qualified and competent to do the work, you DO want someone that will stand behind their work and you DON'T want Mr. Goodpliers in there hacking your ride.
ezone is offline
Old 11-25-2015
Mad Dog Tannen's Avatar
That is a slipping clutch. You need a new one, and pressure plate, and flywheel and throw out bearing.
It could be kinda pricey. Go to a non-dealer Honda specialist to save money, the dealer will guaranteed be more expensive. A transmission specialist might also be a good place to look.
I would get a heavy duty clutch plate and disk for normal driving. Or something more if you like to race it.
Mad Dog Tannen is offline
1khilari
07-09-2015 08:12 PM
Bounddyy
07-08-2015 11:22 AM
Causemo
07-05-2015 06:42 AM
roger t
06-22-2015 07:25 PM
RIPSAW
06-09-2015 08:33 PM
Quick Reply: Clutch Wont Disengage
