D17A motor number explanation
Rep Power: 0 D17A motor number explanation
Hi all,
I'm referring to the VTEC motor number, there is a one digit number under the serial number.
Does anyone know what is this number refers?
https://www.civicforums.com/forums/m...1-motor-no.gif
Received 1,146 Likes
Rep Power: 485 Re: D17A motor number explanation
Moved to the correct location
*not my picture, taken from google images*
are you talking about the top number or the bottom number?
Dr Krieger of Modification
-The D is the style of block
-17 is the engine displacement 1.7L
-and the letter or letter number combo is the head type
so all D17 engines should have basically the same block (maybe different internals)
but with a different head option
the head options are
A, A1, A2, A5, A6, A7, A8 and A9 (I did not find any info on an A3 or A4)
The D17a
Is the JDM 01-05 base civic, VTEC headed D17 block
***The fallowing info is from an app and should be cross referenced before used!!!***
D17A
Displacement: 1668 cc
bore: 75mm
stroke: 94.4mm
strock bore ratio: 1.25
deck height: 212mm
valvetrain: SOHC 16 Valve VTEC
camgear: 38 teeth
power: 127-130 hp
torque: 114 lb-ft
The D17a
D17A
bore: 75mm
stroke: 94.4mm
deck height: 212mm
camgear: 38 teeth
power: 127-130 hp
torque: 114 lb-ft
Received 1,441 Likes
Rep Power: 338 Re: D17A motor number explanation
The D17a
D17A
bore: 75mm
stroke: 94.4mm
deck height: 212mm
camgear: 38 teeth
power: 127-130 hp
torque: 114 lb-ft
The D17a
D17A
bore: 75mm
stroke: 94.4mm
deck height: 212mm
camgear: 38 teeth
power: 127-130 hp
torque: 114 lb-ft
Well ya I was just trying to give an example of what the engine number meant, not every difference... then we'd be here all night talking about each engine, the power differences the compression, the stock bolt-ons (exhaust mani vs header, o2 sensors...)
but good point on the cr. =D
Eh, o2 sensors are the same from a1 to a2. The difference happened in 04 for that. lol
Rep Power: 0 Re: D17A motor number explanation
Thanks for useful information, I'm talking about the number as explained in the following picture;
EDIT: Wrong thread. Oops.
I think the 2 below the serial number stamping is not relevant to the engine type.
mold number used to cast engine?
in other words, why do you think it matters?
alxz310
07-30-2015 12:18 PM
cizsak
07-21-2015 03:39 PM
