Please Help: Need Correct O2 Sensor (quickly?)
Rep Power: 0 Please Help: Need Correct O2 Sensor (quickly?)
Hi All,
I'm that guy so apologies upfront. I recently ordered a replacement O2 sensor for my GF's 2003 EX. Took the old one out, stood up to compare it to the replacement and accidentally broke it. To top it off, the Bosch was the wrong dang part! So with no car right now and an Amazon Prime subscription, I figured I'd order a next day shipping option but cannot figure out which is the correct one. Denso says it's but that involves wiring, (i'd strongly prefer to get one with a harness). When looking around, it basically looks like Amazon calls everything "Downstream" when I'm trying to replace the one on the front. That sucks because model looks like a good fit. But even Denso calls this one "Downstream" too.
Anyone know what I could order for the front O2 sensor on a 2003 EX, (D17A2 engine) that includes a harness?
Fits According to Amazon
Re: Please Help: Need Correct O2 Sensor (quickly?)
You need NTK O2 front (upstream) sensor. This is the original equipment.
Advanceautoparts sells it for $55.99 Part No. 24291 It is made in Japan
http://shop.advanceautoparts.com/p/n...rchTerm=sensor
Autozone doesn't offer it
Rep Power: 0 Re: Please Help: Need Correct O2 Sensor (quickly?)
Thanks emich! Only problem is not having access to a car at the moment, (not sure how bad it would be to drive w/o a O2 sensor). That said, I went ahead and ordered the so I can get it tomorrow. According to http://www.ngksparkplugs.com/part_finder/car_truck_suv/results.asp, it's the "pre cat" and a fit for the D17A2. If it doesn't work out too perfectly, at least I'll have something to throw in there and get me to Advance tomorrow.
Thanks again!
Thanks again!
FWIW, pretty good videos:
Received 1,144 Likes
Rep Power: 485 Re: Please Help: Need Correct O2 Sensor (quickly?)
No thread lock. Anti-seize, if anything. I tighten them down so they're nice and snug; I don't necessarily bust out the torque wrench for them. If you want an actual torque spec, it's something like 33ft-lbs
Removal is simply disconnect harness, 17mm (I think) wrench (open ended. Use a box wrench, you're gonna have to undo it all to get the wrench off) to get it off, installation is reverse of removal.
edit: BootyDo is kinda correct for EX removal/installation vs LX/DX. It all has to do with the location of the cat. EX, the cat is underneath the car, so the O2 sensors are located a bit upstream (just before the bend of the downpipe), and immediately downstream of the cat, before the mid-pipe flange. The DX/LX has the cat located as an integral part of the exhaust manifold, so one sensor is located at the collector for the 4 exhaust runners, and one is presumably immediately downstream of the cat. Physical removal/installation of O2 sensors is the same exact process, however.
I should note, though. OP, ensure you get a sensor for the proper year. 01-03, Honda used a narrowband upstream sensor, and switched to a wideband (much more expensive) sensor in it's place.
Hutch1051
09-29-2015 09:20 AM
Bruce2
09-21-2015 08:01 PM
08-13-2015 03:44 PM
