Can I Install an Aftermarket Keyless Entry System
Rep Power: 0 Can I Install an Aftermarket Keyless Entry System
Hey,
I've been having problems with not being able to turn my lock on the driver's side with the key. I popped the side of the door last night and found that the problem is with the tumbler system itself, which is too expensive for me to fix. Right now I'm just leaving the car unlocked all the time T.T
I'm thinking instead to just buy a keyless entry system (there's already power locks installed on the car).
1. Can I install an aftermarket keyless entry system? (I have an aftermarket radio, does that make a difference?)
2. How much should I be looking to pay if I install it myself (Canada, specifically)? Any recommendations?
3. Are there any good guides for a DIY noob to install said system?
4. Can the system open my trunk as well if included in the kit? The lever from the inside cannot open trunk because the wire corroded off.
5. Any other problems I should consider/look out for?
Thanks.
Thanks.
Prelude Owner
Re: Can I Install an Aftermarket Keyless Entry System
Hey,
Thanks.
Thanks.
I had the same problem with my drivers door. I just removed the tumbler by myself and fixed it. You only have to open it and see if every pin is good. I ended removing one pin that was worn off and was the reason the key wasn't turning. Maybe you should give it a try before buying a keyless entry system
Rep Power: 0 Re: Can I Install an Aftermarket Keyless Entry System
Does this look like a decent cheap option?
Do I just wire it up and throw the unit in the door gap behind the panel?
As for wiring...it's just cutting and stripping wire and connecting them right? Can just buy a connector from the Source or something?
Xpress DX345 Car Alarm with Programmable Hijack System, Trunk Release, Auto Central Lock, 3-Channel Alarm System: Amazon.ca: Electronics
Hi,
Prelude Owner
It's cutting stripping and soldering the wire. I don't know what Source you are referring too?
The unit is usually put under the steering column. All the wires for the doors can be found under the driver kick panel and dash.
Just go out to Home Depot, Lowes, heck, Wal Mart and buy a kit of wire connectors. You can crimp them together, but soldering would be much better.
I found this youtube video that helped a lot. Recode, Rekey Car Door Lock Cylinder - Use Any Key to Unlock Car!!! Ex. Durango - YouTube
Now I have a functioning lock, thanks!
davidarenberg
05-16-2015 08:45 AM
JDQuikCivic
11-22-2001 01:26 PM
