Mugen sports pedal kits, compatible with EM2?
Old 02-08-2015
h4ldol's Avatar
h4ldol is an unknown quantity at this point
Question Mugen sports pedal kits, compatible with EM2?
Couldn't find much from searching about this kit (part#46545-XG5-K2S0) that a website says is compatible with the EM2 but on the Mugen website it doesn't show EM2 as being one of the compatible models for this kit.
https://www.kingmotorsports.com/p-22...al-kit-mt.aspx
I want to buy it but only if it's completely compatible so that it can be installed with absolutely no modifications needed.
Anyone have this one?
h4ldol is offline
Old 02-09-2015
cja3455's Avatar
cja3455 is an unknown quantity at this point
Re: Mugen sports pedal kits, compatible with EM2?
yes they fit, the gas pedal is a PITA to install though
cja3455 is offline
Old 02-10-2015
h4ldol's Avatar
Thanks, I also read that about the gas pedal on a prelude forum but not really sure why, since it sounds like it just slips off. Is the issue just not being able to visualize the tab you have to unhook to remove the pad? Also, there was something about whether or not you should screw into the gas pedal because otherwise it does not have much to "grab" onto?
h4ldol is offline
Old 02-10-2015
lowlife9's Avatar
but honestly save yourself $100 dollars and get these.
http://www.strutking.com/products/Ci...Pedal-Set.html
lowlife9 is offline
Old 02-10-2015
h4ldol's Avatar
I already ordered the Mugen set from ebay for $150. Hope it's not a fake! I do like the foot rest on that set you linked though, I wish I could buy just that.
h4ldol is offline
Old 02-10-2015
cja3455's Avatar
the easiest way is to install the gas pedal over the existing pad, and the tabs should hold fine without drilling into the pedal, just make sure the nuts are very tight on all four corners
cja3455 is offline
Old 02-10-2015
h4ldol's Avatar
Thanks, I'll try that first. I took a look at my, now very old (12.5 years), pedals and the rubber pad on the clutch has actually more than half worn away so that the metal pedal is showing beneath. It looks like I'll need to scrape the remainder of the pads off since there doesn't seem to be enough (at least on the clutch) to simply pull off.
h4ldol is offline
Old 02-11-2015
lowlife9's Avatar
ouch if the ebay seller is not a mugen certified dealer then there most likely going to be fake. strut king is a vendor on most honda forums and are 10% to 15% off for members. also im sure they would gladly sell you the foot rest alone if you contact them. spot the fake http://www.kingmotorsports.com/blog/...-XG5-K2S0.aspx
lowlife9 is offline
Old 02-11-2015
h4ldol's Avatar
Yep, I saw that on kingmotorsports' website and so I should be able to tell if it's a fake or not. I suspect it's real since it's sold by a seller who imports all sorts of Japanese things. In any case, Ebay has pretty good buyer protections so I'm not worried. It was supposed to be delivered today, but hasn't yet...
h4ldol is offline
Old 02-12-2015
lowlife9's Avatar
it doesn't matter if there not certified then your screwed ebay has good seller protection not buyer either way i hope you get the real thing.
lowlife9 is offline
Old 02-12-2015
h4ldol's Avatar
Does the gas pedal actually have a pad that can be removed like the brake and clutch pedals? It seems like a bar with a plastic pad that if you removed would only leave a metal bar rather than an actual pedal to attach the new pedal cover to.
Luckily, I'm pretty sure it's real. Looks just like the one on the king motor sports webpage.
I tried that but it seems impossible, partly due to the placement of the holes and the thickness of the pedal/pad.
h4ldol is offline
Old 02-12-2015
cja3455's Avatar
you don't need to remove the pad, on some models the pedal come as one piece; the screws that come with the pedal are short because they assume you will remove it and drill, go to the hardware store and buy 4 longer machine screws, 4 nuts, and 4 like the one attached in the pic, and use the holes on the top and bottom of the pedal to secure it
cja3455 is offline
Old 02-12-2015
cja3455's Avatar
here's mine installed like this a year ago, no problem whatsoever
cja3455 is offline
Old 02-13-2015
h4ldol's Avatar
I think that's the case with my Civic where there is no removeable pad (and none shows in the parts diagrams on online OEM parts shops whereas the clutch and brake pedals do have pads). I may try what you suggested in the future as I already screwed on the Mugen pedal cover to the rubbery plastic throttle pedal. It wasn't exactly satisfying to do it this way but it seems pretty securely attached.
Looks good! I wish the throttle pedal had a removeable cover because I don't really like the idea of attaching the new cover on top of the old cover.
h4ldol is offline
Donahue
09-08-2015 09:00 AM
Amulon
08-18-2015 11:03 AM
JetsterDajet
08-15-2015 08:07 AM
protoCall7
Bolt-on Engine Performance
07-26-2015 07:41 PM
stvpagn
07-09-2015 09:59 PM
Quick Reply: Mugen sports pedal kits, compatible with EM2?
