Sponsored by:
Sponsored by: DashLynx
Tdc
Old 02-07-2015
jmavila02's Avatar
jmavila02 is an unknown quantity at this point
Tdc
I'm working on my 01 Honda civic EX trying to figure out what's making the coolant spill out the reservoir. So I'm following the Honda manual and in the "timing belt removal" part of the manual it mentions to position the crankshaft at TDC. It does not talk about putting the camshaft on TDC only when installing the belt. Yet, I see a lot of post where people say to put both the camshaft and crankshaft at TDC. I have my crankshaft at TDC but the camshaft is not at TDC. If I spin the cam to put it at TDC then then crankshaft gets out of TDC! I'm confused and could use some guidance. Thank you
jmavila02 is offline
Old 02-07-2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: Tdc
Is it over heating or anything? I wouldn't think the timing would be causing any extra pressure on the cooling system. Is the coolant clear or is it milky?
Do you still have the belt on? You should be able to take the belt off and then put them both at TDC. Then put the belt back on. Unless the timing is really off you should only need to move them one or two teeth.
The camshaft has the UP work on pulley and little marks notched into the sides to line up with the top of the cylinder head where the valve cover meets the head.
The crankshaft has marks on the lip of it and there are small pointers to line it up.
drhawkinz is offline
Old 02-07-2015
mikey1's Avatar
Re: Tdc
i can tell you without even seeing the car.....your head gasket is blown
mikey1 is offline
reddawnman
Engine DIY
224
06-03-2023 10:02 PM
nola000
Engine start problems
63
02-17-2023 09:18 PM
Rlss
24
02-26-2016 09:42 PM
7thgensurvivor
33
09-05-2015 08:20 PM
darwin-t
08-15-2015 10:51 AM
Quick Reply: Tdc
