Sponsored by:
Sponsored by: DashLynx
Fog Lights
Old 11-30-2014
andr3w.aquiles's Avatar
andr3w.aquiles is an unknown quantity at this point
Fog Lights
Can anyone give me instructions on how to install fog lights in a 2003 ES1 and how to wire it up
andr3w.aquiles is offline
Old 12-01-2014
Prelude Owner
GolNat's Avatar
Re: Fog Lights
http://www.handa-accessories.com/civic/civ03fogs.pdf
GolNat is offline
Old 12-03-2014
Re: Fog Lights
thanks but im talking ebay fog lights not oem, im pretty sure its not the same steps to install
Old 12-04-2014
cja3455's Avatar
cja3455 is an unknown quantity at this point
Re: Fog Lights
Very similar install, fyi the eBay fog switch melt very easily, many people that install eBay fogs use the oem switch
cja3455 is offline
Old 12-09-2014
lowlife9's Avatar
Re: Fog Lights
i hope your not going to be one of those D-bags that drives with there fogs on 24/7.
lowlife9 is offline
Old 12-09-2014
Re: Fog Lights
All the cool kids do it.
ezone is offline
Old 12-09-2014
Super Moderator
Poopies's Avatar
Re: Fog Lights
S....switch? You mean you DON'T wire them directly to the ignition?
Poopies is offline
Old 12-09-2014
Re: Fog Lights
Nah, you wire them right to the battery. That way there's no flimsy switch to fall apart, go bad, or melt and catch fire.
ezone is offline
Old 12-09-2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Re: Fog Lights
I would hope the lights would come with some instructions. Search the forum, especially the DIY section and search youtube.
bsmiley is offline
Old 12-10-2014
cja3455's Avatar
Re: Fog Lights
the ebay switches are a mimic to oem so instructions should be the same.
suggesting wiring it directly to the battery is really stupid , no offense ezone, it should be wired ignition hot.
BTW, the fogs look really cool on ES1s, look even better with HIDs so you can run them during the day and glare the MFs
cja3455 is offline
Old 12-10-2014
lowlife9's Avatar
Re: Fog Lights
seriously doe theres soccer moms in mini vans around here with hid lows and fogs running 24/7. its so common place now nobody even bothers to flash them anymore.
lowlife9 is offline
Old 12-10-2014
Re: Fog Lights
You couldn't smell the sarcasm?
Never tap power directly from an ignition feed for a high load item such as foglights.
They really should be wired using a relay to the battery as the main power source, and then use whatever other low-amp trigger you want to operate that relay to run the lights.
You could use the ignition feed to trigger the relay, for example.
ezone is offline
Old 12-19-2014
Redneck_cdn's Avatar
Redneck_cdn will become famous soon enough
Re: Fog Lights
LOL..
The Fleabay Foglight kit for a 04/05 Ex I installed came with a decent lights, wiring harness, weather pack style connectors c/w relay, interior wiring, switch and even a fuse but no instructions ??? .
Installation required removing the front bumper cover to remove the fog light cutouts, install the lights in the lower bumper cover and properly route & secure the supplied wiring harness.
There are a number of instructional tutorials on this forum as well as videos on Youtube that you can use for reference to determine if you are up to the task. It took longer to locate a proper switched ignition power source for the interior low current control switch than it did to complete the light installation and bumper cover re-re.
** Fuses are your friend***
Redneck_cdn is offline
Old 01-04-2015
Pete6032's Avatar
Pete6032 is an unknown quantity at this point
Re: Fog Lights
Anyone that has installed fogs, how difficult is it to cut the bumper with a hack saw? Does it go quickly or is it a pain in the butt?
Pete6032 is offline
Old 01-04-2015
Re: Fog Lights
At work I use an air powered Sabre saw. Super fast for me.
A handy tool for cutting the holes in the plastic bumper cover is a hand held drywall saw. I'd suggest a finer tooth blade than what one would use for drywall though, but it's dang easy.
Home Depot/Lowes/hardware store?
ezone is offline
Old 01-07-2015
Re: Fog Lights
On my 04 I only had to use a box cutter to gently cut the filler plate out, took less than 30 seconds/side and then carefully marked/drilled out pivot hole for each light that is cast into the light mounting side with molded dots.
On the 04/05 bumper, only remove the back part (flat) of the filler, do not just lop off the housing with a chainsaw or you will be buying a new bumper cover. The plastic was very thin and cut easily.
XXLUV2EXCELR8XX
12-16-2001 04:56 PM
LuvMyCivic
12-12-2001 10:02 PM
klam
11-19-2001 05:46 AM
klam
11-16-2001 03:36 PM
780
11-13-2001 09:32 PM
Quick Reply: Fog Lights
