Engine R&R Question
Old 11-21-2014
Steve340's Avatar
Steve340 is an unknown quantity at this point
Wink Engine R&R Question
Hi, I have a 2001 Civic EX, I have to change the engine, Is it possible to remove the engine out the top, without removing anything else, or do you drop the entire assy from the bottom?
Thank you in advance.
Steve
Steve340 is offline
Old 11-22-2014
mikey1's Avatar
Re: Engine R&R Question
out the top on these vehicles is the normal procedure as far as i know
mikey1 is offline
Old 11-25-2014
Received 1,143 Likes on 798 Posts
Manual says pull it out the bottom. I've pulled and reinstalled my engine from the top with the tranny still attached, no less. So yes, you can. Just make sure you don't pinch or crush any lines or anything on the way in or out.
xRiCeBoYx is offline
Old 12-03-2014
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Depends if its auto or manual. You can pull the engine out the top by itself with an auto, but you have to disconnect the convertor etc from the engine. Both would come out, but it would definitely be a fight. Don't know about a manual, would probably have to disconnect the pressure plate from the flywheel while in the car. IF you can get the car high enough it actually isn't that bad to take the whole thing out the bottom. I personally would set the engine/trans/sub-frame assembly on jack stands and raise the car off it, this would require a lift or several guys to lift the car up and over the assembly. Be aware though, if the sub-frame comes off you need an alignment.
johndeerebones is offline
Old 12-03-2014
all-lude's Avatar
all-lude is an unknown quantity at this point
Why would you need an alignment if you drop the subframe? I suppose it would be a good idea but definitely not necessary. I did an auto to manual swap and at the same time replaced the engine. I removed the hood and pulled it thru the top. The auto was tight coming out, had to readjust the engine angle half way to clear the ABS unit.
But I replaced the subframe after the engine was removed, and I did not get an alignment after... Theory being, alignment was already set prior to removal, as long as you don't adjust or replace tie-rods, alignment will stay the same
all-lude is offline
thana
06-15-2020 07:05 PM
Bruce.Ringler
06-18-2015 08:12 AM
zack22490
04-29-2015 03:17 PM
supercivic01
South
11-30-2001 11:27 AM
Grazzhopper
11-11-2001 08:06 AM
Quick Reply: Engine R&R Question
