Sponsored by:
Sponsored by: DashLynx
radio code while radio works.
Old 11-05-2014
rocky_mountain_'s Avatar
rocky_mountain_ is an unknown quantity at this point
I have a 2002 honda civic lx coupe. Just purchased, about a month ago. I don't know if there's already a thread like this, sorry if there is. But I need to change my battery soon, I was wondering if there was any way to get the code by pressing a button on my radio to get the code. The radio is fully functional. I've looked in the glove, wasnt there.
1. can I press some buttons for the code to be view, like #1, #2, #3, or w/e.
2. Where else would that code be?
Alright, any help would be appreciated thanks.
rocky_mountain_ is offline
Old 11-05-2014
jtg199's Avatar
jtg199 is an unknown quantity at this point
Re: radio code while radio works.
Not sure how to see if it will give you a code while it works, but you can try this after you change the battery and don't know the code.
https://www.civicforums.com/forums/1...adio-code.html
jtg199 is offline
Old 11-06-2014
How can the radio be fully functional if it's asking for a code? LOL.
There could be a radio code card with the owners manual stuff, there could be a sticker placed....damn near anywhere inside or outside the car....I've found them stuck inside and outside the glovebox, on the far outside of the glovebox so you have to run around the car like a Chinese fire drill to read it, found them in door jambs, on the battery hold down, on a trunklid hinge, under the speaker shelf....... And unless you are already familiar with what the sticker looks like you might never know what it is. The sticker could only show the serial number, or only a 5 digit code, or both.
The sticker will be about 1 1/2 inches long and 1/2 inch wide
Follow the link in the previous post.
ezone is offline
Old 11-06-2014
CraigW's Avatar
7th gens had the stickers so you may luck out.
When I did my 05 I had a set or batteries at somewhere around 12volts and jumpered them across before disconnecting the battery. (too lazy to set clock and enter presets)
CraigW is offline
Old 11-07-2014
Alright Thanks guys, just worried I won't have the code after I change the battery, I'll use that link if anything. Last i went in to the dealership for my uncles car they gave me the code in like 5 minuets no problem.
I was planning on changing the component speakers putting sk653 6.5 300w in front with the adapter and pc65.2 6.5 500w in the back. Just for now until I get some money probably for those 13 inch JL that are thin. Would this setup be good enough? Does anyone have these or do you recommended something else?
mistermenphis22
07-13-2015 04:43 PM
paddystrang
05-18-2015 09:56 PM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
Quick Reply: radio code while radio works.
