2001 Honda Civic overheating...
Rep Power: 0 2001 Honda Civic overheating...
Here's my problem, I was attempting to drive from Pensacola, FL to Houston, TX and I made it to Mississippi (100 miles) and I noticed the temp gauge started to quickly climb upwards. 90% of those miles were on I-10 doing about 75. I immediately pulled over on the side of the road and let the car cool off. I then proceeded to drive to the next exit to check under the hood. I noticed there was fresh coolant on the radiator cap and in a spray pattern behind the cap on the motor. I waited until the engine cooled off and filled the radiator back with coolant and drove back to Pensacola with no issues. Since then, I have replaced the radiator cap and I put a new motor in the coolant fan (A/C fan was working but coolant fan was not). Since then I haven't driven more than 15 miles at a time just to and from work. Should I check/replace anything else before attempting to make another long distance trip?
Edit: I have taken the car to the mechanic and had them pressure test the coolant system and they said they could find no leaks in the system.
*watches temp gauge like a hawkboss* :D
1 Post
Rep Power: 130 Re: 2001 Honda Civic overheating...
Head gasket.
Look up ezone's links for how to properly pressure test the cylinders to reveal if your 7th-gen's finally needed one. A conventional cooling system pressure test isn't going to reveal a failed gasket on this engine.
If the engine was allowed to overheat just so, you may also need to mill the head to correct a warp. Keep that in mind when paying to fix this problem. New HG with a warped head will fail again in short order.
i just fixed my head gasket myself a little after 200,000KM. same issue as the OP. head was warped got it machined. if your gonna do the head gasket u might as well do a full tune up at the same time (at least that's what i did lol). new plugs, water pump, all belts including timing belt, air filter etc..
LionSpratt
01-29-2017 11:07 PM
aZnVoYCe
Bolt-on Engine Performance
11-04-2001 10:18 AM
