rear sway bar links question
Rep Power: 0 rear sway bar links question
I upgraded my rear swaybar to a 22mm dc5 typer swaybar, the car handles much better with this upgrade but after the install the endlink upper joint pins are not aligned at the center of their range of movement when car is parked on straight ground, they are going about 30 degrees upward from their center, is this ok or does the sway bar assembly need to be diassembled and assembled again ? the bar and link are solid and there's no play whatsoever which is why i'm hesitant on redoing it. it's a pain to get those perfectly aligned, any tricks on getting a perfect alignment on those ?
Received 1,440 Likes
Rep Power: 338 Re: rear sway bar links question
should not be a problem. if it bothers you, get an adjustable endlink when they go out?
mrohitredd
06-09-2015 06:37 AM
Rogelio Rey
05-24-2015 08:30 PM
Dorval Andre
05-01-2015 09:37 AM
CapYoda
11-11-2001 05:17 PM
