Need complete Engine 2004 Civic EX coupe
Rep Power: 0 Need complete Engine 2004 Civic EX coupe
Anyone know of a good priced engine replacement place to replace this 1.7L vtec. Had the head gasket redone almost 2 yrs. ago with new belts/water pump/radiator etc. and now it's overheating again and the place that did the work said it's a bad engine and compression test shows it's internal. Everywhere I check it cost about $800.00 for used Japanese engine and anywhere between $400-$500 to install them. Don't know if that's the best solution other than to dump this model as I know many people with this engine shows same overheating issue. I don't want to spend more money if these replacement engines will do the same later on with its bad history. Would like to know what replacement option I have and route to go if any before I pull the trigger on getting the same type of engine.
Prelude Owner
Re: Need complete Engine 2004 Civic EX coupe
A new head gasket should last you longer then 2 years, it not a Neon. Was it replaced with a cheapo gasket?
You take a gamble with any engine. Do you really love the car? Still hard to find a decent running car for $1300. You might dump this car and buy one that isn't any better (unless you want to spend more money).
Rep Power: 0 Re: Need complete Engine 2004 Civic EX coupe
Well the car was replaced using only parts from the Honda Dealer. Head was taken to machine shop as well prior to re-install by trained mechanic. I guess i was just unlucky for it to be broken again, but this time it's not a blown head gasket but rather something internal engine that went bad causing it to overheat from time to time. Pressure test shows it has compression on the coolant.
lilbluecivic
11-07-2001 06:49 PM
ZSKCivic01
11-04-2001 08:47 PM
