Sponsored by:
Sponsored by: DashLynx
Short Ram Air
Old 05-12-2014
UM4R3X's Avatar
UM4R3X is an unknown quantity at this point
Question Short Ram Air
I was wondering if these actually add horsepower or torque, or anything beneficial, because mighty car mods proved cold air intakes don't do anything, but I was wondering about these.
Thanks!
UM4R3X is offline
Old 05-13-2014
Super Moderator
Poopies's Avatar
Re: Short Ram Air
You have a 7th gen? The results are highly arguable. SRI works on the same concept as a CAI but:
a.) It uses warmer air from the engine bay, potentially increasing mpg but decrease performance.
b.) It isn't nearly as susceptible to hydrolock since it's so high. I have gotten a little water on mine from splashing in puddles, though.
c.) It makes a cool noise when you stomp on the pedal. If that's your thing.
I personally feel like my SRI added power (3 hp would be really optimistic) but that could be me trying to justify my purchase.
Poopies is offline
Old 05-13-2014
mikey1's Avatar
Re: Short Ram Air
all it will add is noise, if you dont want the added noise you would be better off going with a K+N filter that fits into the stock filter housing/air box
mikey1 is offline
Old 05-13-2014
*watches temp gauge like a hawkboss* :D
kinakoes2's Avatar
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Re: Short Ram Air
The D17 has speed-density FI, which means the car figures out how much fuel needs to be injected by taking manifold pressure, air temp, coolant temp and rpm, then referring to a map. It doesn't directly measure how much air is going in, only checking if it did the right thing with the upstream O2/LAF sensor.
This is lower-cost typically than a MAF-equipped system, but since it refers to a fixed map based on what air *should* be going in, adding more won't get you more performance (though IME it will get you more mpg through less intake resistance, I'm guessing). This is why the D17 is more difficult to get power out of than the Ks, and why it doesn't respond to bolt-ons like SRIs and CAIs as well, unless a mod that modifies what the sensors are reading is also installed (how it's done on sportbikes).
kinakoes2 is offline
Old 05-13-2014
kinakoes2's Avatar
Re: Short Ram Air
My guess as to why the CAIs seem to give more noticeable results (based heavily on the quality and design of the intake, as always), is that the longer you make a tube of a certain diameter, the more resistance to flow it has overall. An SRI will be more or less a consistent diameter over a shorter length, meaning more flow if designed competently, while a CAI will be longer with the same diameter. Anyone who's ridden a motorcycle with the airbox off but all sensors still connected will agree -- sure it revs a touch faster, but once loaded, falls on its face -- the engine is designed around the flow and resonance the airbox provides.
If you need proof of the length=flow resistance rule, drink through some 1/4" ID clear tubing 10" long, then 20" long. Your diaphragm is the piston, and ambient air pressure finds it harder to force strawberry Quik into your gob, the longer you make the tubing.
So if the D17 is expecting a certain amount of air to mix fuel with, the CAI provides closer to stock flow for most situations than the SRI, plus a bit more than stock at higher rpm, boosting midrange torque at some spots and improving driveability. Add to that the source intake air temp on a CAI is lower and denser (typically) than a SRI's will also add a touch of power... but not as much as on an MAF engine, which adapts to what is actually going in.
Old 05-13-2014
UM4R3X's Avatar
Re: Short Ram Air
Ok thanks guys. What should I add to increase performance then? Whether it be handling or hp? For sound I'll just get a louder exhaust.
UM4R3X is offline
Old 05-13-2014
kinakoes2's Avatar
Re: Short Ram Air
There are gains to be had from CAIs and SRIs... just don't expect the same results as with MAF FI systems (Ks)... not poo-pooing mods on the D17, just setting expectations realistically.
Thing about increasing flow to get power... is the engine can only increase total flow if both intake and exhaust flow is increased -- meaning carefully-chosen intake mods need carefully-chosen exhaust mods for best results... which usually means a piggyback or standalone fuel management solution, too. A lot of owners think they'll get noticeable power if they just get an SRI... which is typical of those who don't understand how engines work best.
I like the suspension aftermarket for Hondas, even though the 7th-gens don't have the trick wishbone fronts like gens previous. You'll have a lot more fun (and save some gas too) by upgrading legs and brakes, then adding in power -- it's a lot more fun in a chassis that can handle it.
Old 05-14-2014
lowlife9's Avatar
Re: Short Ram Air
i knew before hand that a aem short ram wouldn't do a dam thing for hp i got it because it has a lifetime filter and is extremely easy to clean and replace compared to stock and it looks kool and gets all the bitches. bitches love short rams.
lowlife9 is offline
Old 05-14-2014
Re: Short Ram Air
And Strawberry Quick.
Through a crazy straw.
ezone is offline
Old 05-16-2014
kinakoes2's Avatar
Re: Short Ram Air
That's why I have a sportbike -- if you think having them ride shotgun is fun... try squished against your back doing 0-60 in 4.5 secs (3.0 secs with my old YZF1000R).
I'd rather actually go fast in my car, without the LEO attention (stock pipes on my bike, a turbo on a car). That's from 25 yrs of getting tickets, and trust me, much more fun, not to mention a better closer when you pass all the loud cars/bikes on a set of twisties.
Old 05-16-2014
kinakoes2's Avatar
Re: Short Ram Air
Originally Posted by ezone
And Strawberry Quick. Through a crazy straw.
Quick rule of thumb:
-- for equal length of tubing, when radius is halved, resistance increases 16-fold.
-- when length is doubled for equal radius, resistance doubles. This is for arrow-straight, smooth-bore tubes; bends have their own contributors to flow resistance...
And re: Quik and crazy straws and b*****s: depends on how hard the candidate sucks!
Old 07-07-2014
Civic for life
abodhalmomani's Avatar
abodhalmomani is an unknown quantity at this point
Re: Short Ram Air
I installed a k&n high air flow into my civic 2005 on a d14a1 and Im having a problem with engine it keeps shaking and I lose power sometimes by 80% while driving I tested on the computer its saying. ( intake-manifold pressure power input too high)
Can anyone help me with that..
By the way the sound of that air filter makes u feel that ur driving a Ferrari
abodhalmomani is offline
Old 07-07-2014
lowlife9's Avatar
Re: Short Ram Air
did you reset the ecu and perform idle re-learn ???
lowlife9 is offline
Old 07-08-2014
Civic for life
Re: Short Ram Air
No how to reset??? ... ad dose this problem let the engine start shaking and losing 80% of power?
Thanks for replying
Aznnp77
12-26-2001 10:38 PM
KUNZ
Bolt-on Engine Performance
12-20-2001 07:55 PM
MyOtherRideIsBritney
12-14-2001 04:05 PM
JDock
12-05-2001 11:52 AM
onelifetolive
11-10-2001 10:58 AM
Quick Reply: Short Ram Air
