Sponsored by:
Sponsored by: DashLynx
Help identifying this trim part exterior window sedan
Old 05-04-2014
Pete6032's Avatar
Pete6032 is an unknown quantity at this point
Can someone help me figure out what the part number is for this piece of trim, and if it is easy to install? This is a 2001 sedan. See picture. The trim is cracking, from old age and spending its life outside, and I'd like to replace. Can't seem to figure it out from the part diagrams I see online.
Pete6032 is offline
Old 05-04-2014
*watches temp gauge like a hawkboss* :D
kinakoes2's Avatar
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Re: Help identifying this trim part exterior window sedan
72375-S5A-003 004 001 WEATHERSTRIP, L. FR. DOOR (INNER)
kinakoes2 is offline
Old 05-04-2014
Pete6032's Avatar
I think that is for the inside part of the door. I found this, maybe it is part #1 here?
http://www.hondapartscheap.com/auto-...peed-automatic
Has anyone replaced this before? Is it easy to do?
Pete6032 is offline
Old 05-04-2014
Part #s 1,4,7,9 are the belt mouldings you want, the horizontal black strips at the bottom of the windows, exterior.
Not real hard IIRC, you may need to peel off the mirrors though. Been a long time since I've done any, nobody wants to *PAY* for those after warranty runs out.
The "protector" (#15-19) is the body side moulding, the door ding guard strip lower on the door. Clue is those are painted body color.
EDIT: How did I manage to read 15 from a #1 in the above post?
HTH
ezone is offline
Old 05-04-2014
Javage's Avatar
Javage is an unknown quantity at this point
Mine are much worse than yours, on my coupe they were held on by 4 plastic retainers...I broke a few removing my trim. I then sanded them down some and spray bombed with flat black. If I was more worried about it, I would probably use some plastidip stuff.
Best bet is to roll the window down, take the mirror off and you should be able to get them to pop off.
It should be this one: 72450-S5D-A12 004 001 MOLDING ASSY., L. FR. DOOR 35.80 25.06 Qty:
http://www.hondaautomotiveparts.com/...OR&vinsrch=yes
Javage is offline
Old 05-04-2014
kinakoes2's Avatar
Ugh, you're right Pete6032! Guh... so many parts on cars. XP
Old 05-04-2014
Javage's Avatar
#4, you want the Left side/Driver side.
Javage is offline
Old 05-04-2014
kinakoes2's Avatar
Gonna go back to bed, my brain... been up since 0230 with neighbors arguing at the top of their lungs with a couple of bums... who of course will comply without any retaliation, if you shout at them to shut the eff up in the middle of the night from your apartment window.
numbersguy
Electrical DIY
09-15-2018 11:24 PM
ImmortalEX
Detailing
78
09-04-2015 05:35 PM
drhawkinz
05-16-2015 11:39 AM
jstotts
04-20-2015 09:32 PM
BabyLX
11-08-2001 09:25 AM
Quick Reply: Help identifying this trim part exterior window sedan
