Struts for DX
Rep Power: 0 Struts for DX
I see a couple of rear Quick Struts on Craigslist for 100 bucks a pair. I have a reply as to if they come with a warrantee. Which struts are OEM and do you folks get for your 07 generation Civic's? What is usually the labor to install them? Alignment needed after install? At 63K on a 9 year old car should I need them? Thanks in advance! Great site!
Rep Power: 0 Re: Struts for DX
No they seem OK but if the Monroes are decent I might just replace em anyway if the labor is reasonable. My kid will be hauling around a full car I bet so maybe just buy em and hold on to them. Who knows what I can get em for on craigs
Re: Struts for DX
I wouldn't use Monroe on my car.
I dislike quick struts simply because I've seen many with problems like rattles and clunks......you can't fix them with OE parts after that either.
We don't install them at our shop.
If you don't need springs, then buy just the shock absorber portion, not the entire strut.
If you want them to last, get them from an OEM.
Pull them out, take them to someone with a strut compressor.
Swap springs to the new shocks.
Reinstall into car.
No alignment needed if you do it right.
It's a DIY for some people........until you find out the bolts are seized into the bottom bushing and you can't get them apart. You are in Wisconsin, 99% chance they will be seized.
If yours are still good, don't leak and don't bounce excessively, IMO don't touch them. The car will need money spent on other things soon enough.
HTH
Reinstall into car.
HTH
Speaking about other things down the road. I hear talk about transmissions, head gasgets, how does the civic get such high praise for reliability on many publications and sites?
Received 1,440 Likes
Rep Power: 338 Re: Struts for DX
because up to the 6th gen was more reliable than the 7th gen
Why do you all even own the 7th generation? Ya put a engine tranny into the picture ya might as well drive an Avalon. Where is the economy of the seventh generation, the the 8th has block issues geez. Guess I learned to late shame on the media for portraying such a sound car. Anyway
Re: Struts for DX
YOU have one.
Ya put a engine tranny into the picture ya might as well drive an Avalon. As I said in the other thread, "Don't be scurred!"
Don't sweat the head gasket until it actually needs one. You might never need it.
Why the trans? They got the big problems solved for the most part after the first couple years of the model run.
We now have a tech in the shop that came from Toyota. From the way he talks, apparently Toyota can't get a decent water pump. If you get 40k on a water pump of theirs, you got a great one.
Bigger, heavier car? More safety?
My 12 Civic is bigger than early Accords. My 12 is almost as big as my old Park Avenue.
Just the first couple years of the production run, and probably less than 1% are actually affected by the problem (my opinion)....and Honda addressed the situation with a warranty extension that covers the issue for 10 years and unlimited mileage.
How many other manufacturers step up to the plate like that? Seriously, how many?
Hey, I see a pattern here. The first couple years of a production run have all the problems. By the end of the production run, the engineers finally get most of the problems fixed.
I've heard this before. It applies to almost all cars.
Ain't nuthin' really wrong with your car yet, is there?
By God, you've already crashed the plane before it ever got off the ground!
I know I do, I have the last year of the 7th. So keep it in perspective I get the feeling yur saying they are all not bad keep yur finger crossed. But a water pump compared to a tranny, HG I have owned Toyotas for years LS 430, Camry hybrid, now a Highlander.
Thanks for listenign I did own a 98 accord drove it from 30 k to 130k a 125 dollar ingition fix was it.
Re: Struts for DX
You only get to hear people complaining about the bad ones.
You will never hear someone complaining theirs hasn't broke yet.
*watches temp gauge like a hawkboss* :D
1 Post
Rep Power: 130 Re: Struts for DX
If that was a pre-2009 Camry hybrid... that 2AZ-FXE engine is as bad or worse than the D17A1/2 for breaking seal on their HGs and even more shockingly, stripping fastener threads right out of the block. Figures that the engine family that caused Toyota the most costly overheating/head warp/thread pull problems in their history (and it was used in a LOT of their products), was called 'AZ'. The 2AR-FE that replaced it is far superior... no connection unfortunately to Arkansas.
Some do it, some don't... accurate. But that's also accurate in the Toyota runaway fiasco for affected cars, and the Cobalt fartdrag GM is eyeballs up to now. Should you be proactive, and arm yourself with knowledge to prevent doing/buying/hurting more than you have to? Of course.
That Toy tech via ezone, is correct -- even my Paseo, which was pretty much Old-Toyota-bulletproof... shed a water pump a few months after I bought it at 45K... so not a new problem. The replacement though, lasted 232K, and was still not weeping when I sold it. Not sure why, but have a hunch it has to do with their casting machining/finishing process, with that list of symptom progression. Once the coolant is swapped for the first time... there isn't anything left to kill the mechanical seal anymore? Hope it's not that simple.
It was an 09 hybrid I got during the runaway fiasco bought low sold high. Come to think of it needed a new water pump under 30k. Thanks for all your knowledge to keep it in perspective.
Again this is for my kid and then for me$ to sort out long term. Thinking I should have gotten the 04 Lesabre limited I could have gotten for 3k$ with 100k on it from a ol guy. But then they had issues with the plenum but not and engine or tranny.
The most reliable and easy to fix car i have is my 95 miata
the other was my old beetle, 15 min and the engine was off the car. just need the right spare parts in the car, like the belts, or the ignitor
did a 80 mile trip on only two cylinders, i just should never turn the engine off until i got there.
Re: Struts for DX
My mother HAD an 02 Accord w/4 cylinder, about 100k on it.
My grandfather passed on last year and left an 04 Park Avenue Ultra with only 15k on it.
She sold the Accord and kept the Ultra.
It's a gas guzzler around town but it gets within 2 MPG of the Accord on the highway. And it's quiet and smooooooth.
And it screams "LOOK OUT!! OLD PERSON DRIVING!"
